NEUSPEED UPPER FRONT STRUT BAR INSTALL HELP!
Old Mar 3, 2002
BLiTz's Avatar
BLiTz is an unknown quantity at this point
I wanted to install a Neuspeed upper front strut bar for my 2k1 civic but need some detailed help. I looked at the instructions and what I thought was gonna be easy kinda threw me off. Can anyone help me out with a detailed explanation for this?
Thanks!
Old Mar 3, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
take off the screw and than put it on... you will need to take off 4 bolts.
Old Mar 3, 2002
TOOLOWCIVIC's Avatar
Yeah what he said
Old Mar 3, 2002
1028CiViC's Avatar
cause i just took off mine...today..
Old Mar 3, 2002
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
Just make sure when you unscrew the four bolts that your car is on a flat surace.
Old Mar 3, 2002
1028CiViC's Avatar
yea..more safe that way.
Old Mar 4, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
dont worry about the instructions....if ur not sure which bolts just put the strut bar upto it and you'll see which bolts to remove,,,you remove the 2 outside bolts on each side,,,put one side of the strut bar on and on the other side u may have to pull and tug a little but once you have it lined up with the bolts unless u have a deadblow(rubber mallet) just use the palm of ur hand and hit it a couple times,,,u shouldn't need to jack it up,,,and make sure ur wheels are straight....
Old Mar 4, 2002
Erichyung's Avatar
Erichyung is an unknown quantity at this point
Does Neuspeed strut bar fit when you have AEM cold air intake installed?
Old Mar 5, 2002
BLiTz's Avatar
In the box came with four caps and a lug nut. The instructions say tighten something with it like the clutch or something. Can someone let me know more of a detailed info. Thanks to the peepz who left the info!
Anyone interested in buying a new OBX upper front strut bar? I bought it originally for this car but b/c of my AEM CAI it doesn't fit. If you have no intake, an injen one, or an intake that doesn't bulge out this will fit your car.. Let me know..
[IMG]i/expressions/beer_yum.gif[/IMG]
Old Mar 5, 2002
ZZCIVIC's Avatar
ZZCIVIC is an unknown quantity at this point
yes, the neuspeed will fit, as will the DC Sports bar
Old Mar 5, 2002
02CarbonCivic's Avatar
02CarbonCivic is an unknown quantity at this point
the 4 caps just snap over where the holes are just to give it a clean look .... I didnt use the nut, it is to relocate the clutch fluid holder, all I did is loosen it and tilt it to the front of the car a little so it didnt hit the strut bar..... also you will need a torque wrench and torque it to 33lbs
Old Mar 5, 2002
Tetryl75's Avatar
Tetryl75 is an unknown quantity at this point
Thats the same thing I did. I just loosened it and tilted it forward. Works for me. Two thumbs up.
Old Mar 5, 2002
BLiTz's Avatar
Where is the clutch fluid holder located? If I were to use the nut to relocate it where am I suppose to put it? Also I don't have a torque wrench so if I was using a regular one how tight would I have to tighten it?
Old Mar 5, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
Just tighten it until its fairly tight, then give it 1/4 to 1/2 a turn, then your good!
Old Mar 5, 2002
BLiTz's Avatar
Okay that takes care of the tightening question but how about the clutch holder? Shouldn't I use the nut supplied to the clutch holder? Please advise anyone..
Thanks
Old Mar 6, 2002
AllMotorSi's Avatar
Sure you can try, I used the existing one cause I couldn't get the one they gave me to fit. The best way to move your clutch resevoir it to jack up your driverside and then put your hand under the wheel well and feel your way in and tighten the resevoir.
Old Mar 7, 2002
BLiTz's Avatar
Okay, I'm feeling really stupid and this shouldn't be so damn hard and complex. Thanks to the peep'z who has helped so far but I just need a detailed explanation on this all... Just want to make double sure on what I'm doing instead of doing what I'm unsure of..
[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
beachglass
May 22, 2015 09:59 PM
GH04si
Apr 15, 2015 08:13 PM
PlatnumBomb
Bolt-on Engine Performance
Nov 9, 2001 01:11 PM
andylao
Nov 4, 2001 01:19 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
