Duplicolor Paint for engine bay trim?
Old Feb 26, 2002
CivicRiderCA's Avatar
CivicRiderCA is an unknown quantity at this point
I was just at my local autoparts store to buy the primer, paint, and clear coat needed for the painting of my fuse box cover and valve cover under my hood. The only paint they had was the Duplicolor line of Truck, Van & SUV paints. I bought one of each of the above from this line. I am worried now, however that they will not be heat resistant enough for my application. Does anyone know if they are okay? Or did I just screw myself out of $15 (can't take back spray paint).
Thanks
Old Feb 26, 2002
VTEC808's Avatar
VTEC808 is an unknown quantity at this point
The paint you bought should work just fine. The parts you wanna paint aren't going to get hot enough to make that paint crack & peel off, now if you wanted to paint metal engine parts, then you'd have a problem. But you should be fine with what you have & what you wanna paint with it.
Old Feb 26, 2002
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
If you're painting your VALVE cover, then you shoulda gotten HEAT RESISTANT PAINT. If what you are painting is that plastic Spark Plug Cover...then I thnk you'll be alright.
Old Feb 26, 2002
I may have misstyped.... I am painting the black plastic piece on the top of the engine that has the Honda V-Tech on it. Am I okay painting that with this paint?
Sorry for the confusion.
Old Feb 26, 2002
VTEC808's Avatar
Yeah, you'll be fine with what you have
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
superstanko
Apr 28, 2015 04:38 AM
supercivic01
South
Nov 30, 2001 11:27 AM
autobots
Nov 29, 2001 07:27 PM
antidote11
Nov 27, 2001 10:46 PM
