d17
Old Mar 17, 2006
dope_99's Avatar
dope_99 is an unknown quantity at this point
d17
heres the thing i have an 02 lx and im getting an 02 ex engine. how hard is it to put it in since its vtec. also i want to build it up to hold 20 lbs of boost. i dont know if its possible boring them up to a 2.0 even resleeving it so if any one know let me know what i can do.also is there any trans i can put on that will hold up against racing.
Old Mar 17, 2006
tuner04civic's Avatar
spell check pwns you
if the engiine is complete its a remove and put in new engine. vtec is in the head and the transmission is the only one for ur car. civics i jave seen hit high psi. built up the internals but havent seen anone bore out the block to a 2.0l. may be better off with a swap if you want that. save the money.
just use the search button and go in forced induction. theres a few hitting high 200whp.
Old Mar 17, 2006
dope_99's Avatar
i dont want to do the swap i want to see what can be done with these d17 no one likes them i want to be the one to break that trend
Old Mar 17, 2006
well theres a long list of possiblities. dezod is fabricating some god parts for our cars. along with crower and some other brands you can get some power. still a sohc. but tuning is the most critical for power and safety to the engine
Old Mar 17, 2006
dope_99's Avatar
how much can you bore them over, pistons and rods for high boost, cam for high boost, and i cant find a new crank anywhere so. i want to get at least a 12 second 7th gen with out a swap
Old Mar 17, 2006
LiVe bAiT's Avatar
LiVe bAiT is an unknown quantity at this point
do u already have the motor??? if not iv got one for sale with 5speed tranny.
Old Mar 17, 2006
i hear a new crank pulley is not a good idea. if u search theres a few people who put down some big numbers i see 13's not 12's. unless u swap out the motor for a k series
Old Mar 17, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
your not gonna be able to bore a d17 to get to 2L without severly risking your block strength. 20 lbs of boost is a lot, internals is a must and most likely bottom end too, the works its gonna be expensive. good luck though I would like to see a built d17
Old Mar 17, 2006
dezod's Avatar
7thgen Power Maker
I would recommend pistons, rods, and a standalone EMS at minimum.
Old Mar 17, 2006
dope_99's Avatar
money is no problem. i just need some numbers and get me a list going how much can you bore them over and should i go low or high compresion for high boost
Old Mar 17, 2006
dezod's Avatar
7thgen Power Maker
I would not be concerned with over boreing the D17. It actually makes quite a bit of power on the stock D17 bore. If you have more Q's........Pm me.
Donahue
Sep 8, 2015 09:00 AM
KAMIKAZEEx
Aug 30, 2015 08:30 AM
lyanreindecker
Aug 20, 2015 09:15 PM
CivicLude
May 12, 2002 08:01 PM
bo0sT
Apr 3, 2002 09:11 PM
