Problems wiring to Ciggerete lighter
Old Feb 20, 2002
Drew's Avatar
Drew is an unknown quantity at this point
today i tried to wire some neon into the wire coming out of the back of the cigerette lighter. There were two wires, one Black, one yellow, i tried wiring to the yellow one first, and then turned on the car, but the neon did not turn on. i then turned off the car, and wired into the black wire, turned on the car, and again, the neon did not turn on. When wiring, i stripped a bit of the cigerette lighters wire off, then wrapped about an inch of the neons + wire around the stripped part. I had the Ground taped to some metal around the back of the cigerette lighter...
mainly wondering which of the 2 wires i should have the wire going to, and if the power should be constant whent he cars turned on or if maybe somthing needs to be plugged into the cigerrete lighter?
thx.
-drew
Old Feb 20, 2002
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
how many watts do your neons pull? your not suppose try to run much more than 100 off the cig lighter. check the fuse.
Old Feb 20, 2002
Drew's Avatar
the neons power transformer had a ciggerete adapter plug on it, i just chopped that off, then stripped the wire off of that, so i figure it wouldnt be too much voltage. Is There a diff wire that i could try? or a better way to attach the wires without saudering?
-Drew
Old Feb 20, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
your porblem was the ground....if it is grounded to the back of your cig lighter, no good.....try grounding it to a bolt on the car.
Old Feb 20, 2002
Drew's Avatar
i didnt have it grounded to the back of the ciggerete lighter i had it taped onto...
a peice of metal like the one with the screws on that pic. the only thing i can think of that would go wrong witht eh ground is that the adhesive from the taped rubbed off to much on the wire.... but i dont think thats too probable.
-Drew
Old Feb 20, 2002
bobbyd's Avatar
try scraping the crap out of the metal until it is shiny
Old Feb 20, 2002
Drew's Avatar
i will try that tomorrow, i have one other questions for now though, i have a 12V illuminated rocket switch, which i want to turn the neon on and off. it has 3 prongs, Supply Volts, On ACC. and earth ground. Is their a specific kind of wire i need to run to the switch, or will any do? am i correct to think that supply volts is a wire going from the power wire in the car to the switch, the on ACC is going from the neon positive to the switch, and the Earth Ground is a wire ( does it need to be a specific kind? ) that goes from the switch to any metal in the car? Also, the rocker switch came with "solderless terminals" i was wondering how exctly they work, it has a circular blue rubber end, and then goes out to have 2 metal curls on each side of the otehr end. thx. EDIT: also, would i need a fuse in between the connection from the Illuminated switch and the power wire in the car? if so, what kinda fuse?
-Drew
Old Feb 20, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
oiy!
Wiring the neon to a illumated switch, then to the cig. lighter power wire.
Here's a diagram for the switch.
Grab the +12vDC from the yellow wire from the cig ligher.
Then just ground the wires with the black wire that's bolted to the frame.
Old Feb 20, 2002
Drew's Avatar
i think my neon got messed somehow, i couldnt get it to work with the transistor, so then i tired just getting it to work with the tube and couldnt, i got the switch so it lights up though :-D and i made it so it hangs out. Im going to try and buy new neon tomorrow and wire it into the switch that i got to work. One last question though, can u wire a ground wire into another ground wire and that work? THX for all ur help.
-Drew
Old Feb 20, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
return the neon, streetglow and liteglow both have lifetime warentee's if the outer protective plastic isent cracked.
Old Feb 20, 2002
blackerstallion187's Avatar
blackerstallion187 is an unknown quantity at this point
Wiring a ground to another ground should work. I did that on my sound system. I have two amps and instead of having two different grounds on the chassis of the car, I just wired the second amp ground to the first amp ground terminal, and then the first's to the chassis of the car. But it has to be a good ground on the chassis though.
Old Feb 21, 2002
Drew's Avatar
Thx for all ur input, has been alot of help! Stole my friends neon he had, and installed it on mine to see if i could get it to work, and it did! Thx again.
-Drew
4 banger
Jun 5, 2015 01:44 AM
dinsum
May 28, 2015 09:30 PM
Blazz
May 25, 2015 10:56 PM
pincookie1
May 4, 2015 12:22 PM
blackbullet
Dec 1, 2001 03:44 PM
