Driver seat foam removal?
Rep Power: 0 Driver seat foam removal?
Not sure what was the best forum for this and searches didnt show up exactly what I was looking for. But here goes....
My 2002 Civic LX sedan driver seat is killing my back!! I'm used to mid size cars which have alot softer seats. Really like the car but my back is just about shot. We talked about replacement seats...but I want stock looking ones that use the OEM seatbelts...not easy to find. I've heard the SI Civic has nice seats though not sure if they'd fit in or if the boneyards even have any.
I tried different seat cushions but those suck. So...someone suggested trying to replace the OEM foam. Not sure how to remove the seat covering(still searching the net) but has anyone done that and seen how the foam is attached to the back section of the front seat?
Maybe buy some memory foam and replace the section my back sits into....?
TIA!!
TIA!!
Originally Posted by bluestreak
don't know, but alot of my friends complain the seats suck as well.
Removing them looks easy....but how the hell do you get those covers off!?!?
Hope they arent factory sewed at the very bottom.
Originally Posted by fallout
I need to get those covers off too. Not because my back is killing me or anything. I just want to mount my amp back there. Lol.
The only place I can see that the covers come off is on the very bottom...maybe the two sections of the cover(front/back) are latched together somehow. Hopefully someone will know how to get them off.
Rep Power: 233 ^^ Well not on the seat, but on the back of the front and passenger seat.
I have 3 amps and two 15's. The amps are all 17in each so they dont fit in the trunk with the 15's. If i can remove the covers and the foam, maybe i can stuff the amps in there. Lol. It'll also be a custom seat warmer!!
I'll take a look at it after i get home from class.
I think i have too much creativity for my own good.
Rep Power: 0 ^becareful with the amps though, I had hollowed out a piece of foam insulation in my old 300zx to mount an amp and it ended up overheating.
FYI, use an additional fan or something, so you don't overheat
There is gl@ss in my @SS...
Rep Power: 297 Try either buying the RSX seats or the SI seats, you won't regret getting those seats. I think the 7thgen Honda Seats are the most terrible seats for comfort and have to be the ugliest ever! Damn i can't wait till my new Recaro Speed Seats are in!
I'm sorry but thats about retarded if your gonna mount your amps on your seats. there should be plenty of room in the trunk to mount the amps. try mounting them on the back seat. If not mount the to the rear seats not the front.
I figured out how to get the covers pulled up....if I didnt see a pic of the latch I'd never figured it out. At the very bottom of the back of the seat(recline it fully forward)...there is a plastic bar that the front of the OEM covering "plugs" into the back covering. I went to the far end...found the two pieces then pulled them apart slowly...hard to explain but once you see how its snapped together it comes apart easy.
BUT....I need to get the covers up all the way....which means removing the seat. NP with that....but has anyone taken off the plastic covers that are over the reclining lever?? The bolts to remove the back from the base are under that. Looks like it snaps on but I dont want to break anything taking them off. Thanks for any help!
mohawkboom
67
08-25-2015 12:28 AM
