Ground Contorls make noise
Old Feb 17, 2002
01rallyeredex's Avatar
01rallyeredex is an unknown quantity at this point
I have had ground control coilovers on my car for just under a month know and i have this noise coming from the back of my car, it sounds like the little rubber thing that sits between the spring on the coilovers and the strut might be rubing. Has anyone else had this problem or does anyone know how i might be able too fix it.
Thanks,
Old Feb 17, 2002
Voiceofid's Avatar
End Bringer
i don't know anything about suspensions.. but.. could it be the struts?
Old Feb 17, 2002
rhyno's Avatar
rhyno is an unknown quantity at this point
it is the the bushings. On a normal suspension, you would have rubber bushings. With the gc's, you are supplied with urethane bushings. Urethane greatly reduces the amount of deflection that rubber bushings allow under performance driving conditions. This reduction in unwanted suspension movement lets the parts that are designed to move (e.g. shocks, springs) work more purely.
The only drawback is that they may have to be lubricated. You want to use a high quality grease thats gonna resist water and wear. Just grease it up a time or two around the bushing and you'll be good to hook.[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Feb 17, 2002
Cool, thanks Rhyno.
Old Feb 17, 2002
Amphiprion's Avatar
Amphiprion is an unknown quantity at this point
Thanks Rhyno.......my buddy has the same creaking noise coming from his rear wheels.
Old Feb 17, 2002
EcKo2k1Ex's Avatar
EcKo2k1Ex is an unknown quantity at this point
Yeah hes right the bushings just need some grease, It should of came with grease in the pack. I ran into that problem when i had my 99 hatch. i put a progress sway bar on and forgot to grease it and it did the same thing[IMG]i/expressions/face-icon-small-sad.gif[/IMG].
Old Feb 17, 2002
rhyno's Avatar
yeah, i think that gc is sending theres out with little grease tubes now, but i'm not sure. either way, if you give them a call they will send you some.
Old Feb 17, 2002
Is there any place else that i will be able too get some good quality grease.
Old Feb 17, 2002
rhyno's Avatar
like i said, just give them a call and explain the situation. its free and you'll have it in like 3 or 4 days. i couldn't find the grease that i wanted but i just bought some high quality crappo(oxymoron) grease from pepboys. did the trick but its alot messier.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
dosmastr
May 5, 2015 12:19 PM
SSMatey
Apr 13, 2015 06:09 PM
