clearing headlights
Old May 19, 2005
nova4dr_racer's Avatar
nova4dr_racer is an unknown quantity at this point
clearing headlights
anyone tired the DIY clear your headlights
taking bumper out was ez and the headlight too
but breaking the headlight in to was almost impossible.. theres too much housing in it and was never able to fit my finger to seperate the peices ..
anyone has advices?
Old May 19, 2005
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
you need to heat it in the oven so the sealent unbonds, then use something to pry it open such as a flat head screw driver.. its really easy, and the headlights won't break..
Old May 19, 2005
SeeGirLDrifT's Avatar
SeeGirLDrifT is an unknown quantity at this point
did u try putting the headlights in the oven to melt the seal?
I DIYed mine and it was kinda difficult to pry them open, but you just need to heat them up and then its really easy from there.
Old May 19, 2005
ACURAwerx's Avatar
o and when you put it back together make sure you use a lot of sealant so it doesn't leak when you put it back on your car. That happened to me the first time i did it and i twas such a pain to do everything all over again.
Old May 19, 2005
ohnoitssoysauce's Avatar
ohnoitssoysauce is an unknown quantity at this point
i just used a blowdryer and a flat head screwdriver. i think it's a lot faster this way
Old May 19, 2005
clrumivier4life's Avatar
clrumivier4life is an unknown quantity at this point
I didn't need any heat. I pryed it at the round edge then slid the screw driver around the housing to seperate it and it came off real easily. If you happen to touch the chrome or get that black sealent on it, RUBBING ALCOHOL AND Q-TIPS work wonders.
Old May 19, 2005
nick82006's Avatar
nick82006 is an unknown quantity at this point
Blowdryer,small flathead,big flathead.........if u cant get a good angle with the flathead in there try puttin it in and turning it VERY slowely clockwise or counter and that will pry the peices apart but make sure the sealant around it is hot or eles youll turn to hard and crack the plastic.
Old May 19, 2005
orion_squall's Avatar
hey, just use blow driyer.
Don't use anything sharp. just just a flahead with soft tape on it. You don't want to scrach the lens
Old May 20, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
i just used a hairdryer and my hands. no screwdriver needed, are you guys weak or something? lol...
Old May 20, 2005
AzNTiG3R's Avatar
Member
AzNTiG3R is an unknown quantity at this point
The hardest part for me was that one bolt in the lower back part of the driver's side. Once I got the lights off, I just took a small blade and cut thru the silicone crap and went from there.
Old May 20, 2005
If anything, you only need a screwdriver or butter knife to loosen it up... but yea, once its heated and a little loose, just pry them apart with your hands. It's scary at first, especially if you hear cracking sounds... but it's fine.
Old May 20, 2005
CvC-v01's Avatar
CvC-v01 has a little shameless behaviour in the past
use your mom's OVEN.......
I open my trucks light with an OVen...
it was pretty easy......
http://www.7thgencivic.com/forums/sh...d.php?t=210584
good luck
Old May 20, 2005
flipbagz's Avatar
Go Pistons!
flipbagz is an unknown quantity at this point
hahaha yes!!! i thought it was just me who used a hairdryer lol
Old May 20, 2005
Azizst's Avatar
Azizst is an unknown quantity at this point
After you clear your headlights, do the turning signals color change to white if you use the stock signals? Or are they also yellow? I have a little doubt about it.
Old May 20, 2005
boombazokajoe91's Avatar
I survived that B*tch Katrina !!!
boombazokajoe91 is an unknown quantity at this point
i thought the whole thing was pretty dam easy,
Old May 20, 2005
thx guys .. im going to try this. I thought I was weak for a second.. couldnt break it in 2 but never thought of heating it
Old May 20, 2005
anyone has a picture of the result?
Old May 20, 2005
haha.. yea.. even I could do it... and i'm a little girl.
Old May 20, 2005
Here's mine, did it about 2 weeks ago. Such a huge difference. They look so nice.
Old May 20, 2005
^^ those look really good!
Here are mine.. But I kept the orange part and tintied everything with black tint spray.
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
brash99
Sep 29, 2015 08:42 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
