ACT Stage 2 ain't sh1t, purrfect auto sux a$$!!!
Old Mar 28, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
Unhappy ACT Stage 2 ain't ****, purrfect auto sux a$$!!!
Originally Posted by pnoyster2k1cvic
woooooooohooooo! i got me a a 99 Saturn SL2 w/ 91k miles for 5,998 from carmax handling is awesome! but it makes this car like a scooter compared to my boosted civic
this is going to be my girl and my daily driven car from now on... my baby's gonna be garaged most of the time I so fvckin hate it when my car's down... but she's gonna be fine by Thursday
I let it bled for about 6x, i don't know how much do I have to let it bleed... pedal have more pressure this time, and somewhat goes to reverse, but with grinding noise and still won't go in on any gears... i think my clutch's fvcked i'm gonna bleed it again for about 15 times just to quadrople sure that it's not the bubbles in my lines...
I came to a conclusion that I fvcked my clutch... after I bled the clutch for about 10x and put about half a can of brake fluid... it's still the same... now which one is cheaper, get my slave cylinder fix first and see if that's the problem or I have to get me a new clutch... but it's hard to believe that an ACT clutch will pop just like that... unless the installation was faulty... could it be just the cylinder going bad? or could it be the slave cylinder, and or the clutch? man this sucks....
Old Mar 28, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
not exactly sure what's causing that man. but its got to have something to do with the master cylinder. either is bad, or has some air in it when you did the clutch install. Have you tried to bleed the clutch yet? I'd start there.
Old Mar 28, 2005
HyaBoosta's Avatar
yeah you may have air in the lines. or it could be your slave cyl. Make sure it is not cocked at an angle.
Old Mar 28, 2005
Balut Eating Champ
Purrfect Auto installed it for me... i don't mess with breaks, clutch, transmission<<< I only do bolt-ons and what not, I leave those to the pro... the clutch's been on my ride for about 10K miles and it work fine untill now... but how do I bleed my clutch? is it do-able? how easy and how long?
Old Mar 28, 2005
HyaBoosta's Avatar
pop you hood and look on the tranny bell housing just left of the header. there are 2 12mm bolts. the thing with the plastic boot on it is your clutch slave cyl. on the right of it you'll see a little silver bleeder valve. you need to have someone in the car and someone underneith it. Just make sure that the reseviour is filled at all times with brake fluid or your just gonna keep getting air in it. Have them pump the clutch pedal 4 or 5 times to build pressure in the line and then on the last pump have them hold the pedal all the way down. while they hold the pedal down the person under the car takes a 8mm wrench and opens the bleeder valve and let it drain till it stops. then close the bleeder and then they can let the clutch pedal up. keep doing this 3 or 4 times. but make sure every other time you do it you check the resiviour to make sure it always has dot3 brake fluid in it. Good luck
Old Mar 28, 2005
Balut Eating Champ
thanks man! I rep you on that one! i will do this tonight...
the slave cylinder i'm assuming is just right on top of the clutch pedal right? damn i hate being a newb!
but why is it doing now than before? is it because when I shift hard the fluid moves around and that causes the air to go in the hose when I press the clutch? I just wonder how it happens
Old Mar 28, 2005
Balut Eating Champ
fvccccckkkkkkkkkkk!!! i'm sitting here in the office thinking about my car that needs tender, loving and care... I can't concetrate on my work... so i'm here in 7thgen website whoring my own thread i'm fvckin shiverring right now knowing that my car's down for the momment i need to fix her asap... aarrgggghhh! boss can I go home now?
Old Mar 28, 2005
civic01vtec's Avatar
do what hyaboosta said.....but check your fluid level first
Old Mar 28, 2005
Balut Eating Champ
definitely bleed it as soon as I get home... I think I moved alot of the bubbles when I drove her hard last night @13PSI ... my fluid is at below max, I always check my fluid not to go below 2mm from max line ... but yeah i haven't bleed my clutch since my ACT clutch install about a year ago... so maybe from the install had some bubbles there already and it just now caused this problem...
Old Mar 28, 2005
HyaBoosta's Avatar
the clutcj slave resiviour is the smallest one. make sure you have the rubber on the cap tucked in all the way incase it's expanded down all the way.
Old Mar 28, 2005
AlienX's Avatar
AlienX will become famous soon enough
well bleed them already and tell is how it went !!!!!!
Old Mar 28, 2005
Balut Eating Champ
dood! i was ready to go home since i got here to work... but she's waiting outside I think i'm gonna have to get it towed just in case... but yeah I'll let you all know how it goes...
Old Mar 28, 2005
jnh986's Avatar
jnh986 is an unknown quantity at this point
purrfect auto .. in vegas im not to fond of their work ....
Old Mar 28, 2005
Balut Eating Champ
I have a guy that works on cars for quite awhile he did a pretty good job on it... but we'll see if the clutch is fuvked then purrfect auto sux...
Old Mar 28, 2005
Balut Eating Champ
i can't find the damn thing... do I have to be underneath the car to find the clutch bleed? can somebody put a picture up just to give me an idea where exactly is this thing located... thanks guys...
Old Mar 29, 2005
Balut Eating Champ
i found it the fvcker's hiding behind the turbo I let it bled for about 6x I don't know if it takes way more than that for the fluid to travel from the cylinder to the bleed valve... i'm gonna work on her until 1am if this **** ain't working by then, then my clutch is fvck!!!
Old Mar 29, 2005
AlienX's Avatar
its 3am where im from, .. that explains it... philippines. What is the time there ?
Old Mar 29, 2005
HyaBoosta's Avatar
oh yeah I forgot you had a turbo. Mine is just behind the compressor side of the turbo too.
Old Mar 29, 2005
bradmanuwf's Avatar
your turbo might be in the way of it. the slave cylinder is in the bell housing. the master cylinder is attached to the pedal. its a little fitting that has a nipple on it. my turbo is in the way of mine, but I know its there. follow your clutch line and feel around where the clutch line attaches to the bell housing(slave cylinder). I'll put a pic up when I get home if you don't find it.
oops, didn't read the second page....sorry guys
Old Mar 29, 2005
Balut Eating Champ
i'm gonna tear my car apart today... but first off to carmax and get me a new ride hehehe... if my clutch is good... then it's gotta be the clutch cylinder... I don't wanna take it to any shop right now specially if we don't know what the problem is... they will take advantage of me like they do to the rest of their customer... i'm talkin about the auto shops...
Old Mar 29, 2005
Balut Eating Champ
Old Mar 30, 2005
AlienX's Avatar
thats funny.
Why dont you just get ur car towed to a tranny shop ?
Old Mar 30, 2005
Balut Eating Champ
i don't have the time and Thursday is my only day off...
Old Mar 30, 2005
Al Gore FTW's Avatar
jdmtytedoridori
yer not serious about the saturn right? just makin sure lol
Old Mar 30, 2005
AlienX's Avatar
if you can't beat them, join them I think thats what happened there.
Old Mar 30, 2005
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
L E A R N H O W T O S P E L L.
Old Mar 30, 2005
Balut Eating Champ
no seriously i got me one so I can put some down time on my ride... do they break down often? the car's running great... i just don't know if they have alot of problems... i'll search on them...
juror
Suspension DIY
Jul 30, 2019 03:28 AM
alaga
25
Aug 13, 2015 04:42 PM
adamdrives
15
Aug 8, 2015 08:53 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
cizsak
Jul 21, 2015 03:39 PM
