The D17 VTEC controversy (solved).
When I had mine dynoed, they said 2800rpm was the best setting that kept the most power. I just left it on stock passive mode tho cause it seems to feel smoother when the ecu controls it vs the vafcII.
How does this Vtec light thing work, I know there is a DYi on it (but I am to lazy to look for it, sorry), but I am assuming it read the oil pressure and activates the light from that. If this is correct, where does it read the oil pressure from. My other idea is that you some how tap in to the solenoid adn read a voltage from it, assuming it is electronically controlled. Could some one clear up for me just where this VTEC light is taking it's information.
I'm not sure, but my vafcII does the same thing and it's just hooked to ecu wires. Maybe it's the vtec vtm wire? It says the vtec wire, whatever that is.
http://www.7thgencivic.com/forums/sh...ad.php?t=88650
Hummm... so it looks like to me it's an actual electrical signal. Reason I ask is because if it was taking a reading from the oil pressure, the oil pressure could be off making the light come on falsely, but sense it is electrical signal, it is far more accurate than I thought.
That being said, I will say that I have go with the VTEC light and say that I was wrong about a 4,500 engagement point. I too thought it had a variable engagement point. So you say it will come on around 3k if WOT. Say you are at 70 mph, which I guess around 3,200-3,500 rpm, is it on then? I’m just curious.
The readout says engagement around 3200rpms, but that may vary with driving. If you're on the highway with an auto going around 65, the rpms are just under 3k and the light stays off. As soon as I push it to 68-70, the rpms are just above 3k (3090k or something) and the light stays on.
Originally Posted by Jrfish007
I'm sorry, but I just can't stand people flaming when they can easily just say what they think like everybody else on here.
What else was there to discuss? We went over that the D17 has two lobes for the intake, at a certian RPM a pin slides over and engages the the second valve to the first valves cam lobe. It is up for debate as to if it is 2,300 ish RPM or 4,500 ish RPMs. I say 4,500 because I can't see cruising down the highway with VTEC on, VTEC was designed to combine a fuel effiecent with a little extra power, why would you want to use that power fro mainting 65-75? I admit I could be wrong, just seems logical to me.
I mentioned the D16, previous civic EX motor, had three intake lobes and worked on a different system, many people think that system is in effect in on the 7thgen civics today, but they a wrong, it uses the system I described above.
Only thing left to debate is what point or range the VTEC operates in.
Go back to post #18, I contributed - when people start spreading misinformation to others (especially when people are looking at this thread to explain to them how their VTEC works) is when I stepped in (i.e., the "3-disc clutch", "all K-series have 5-speeds, etc.). Now, I'm just pointing these out, not flaming.
The whole reason cruising speeds were brought up was for this simple reason - our cruising speed is a function of gearing, NOT where VTEC activates. Honda sets the VTEC crossover at the point of greatest effectiveness for a gentle and efficient transition (which requires some research into the general flow and air consumption of the engine to find this point). They don't go set the VTEC point by where most people will be cruising.
Honda will set the VTEC point around the engine speed that creates the most benefit (and not as a function of cruising speed) even if that VTEC point means that VTEC is activated at 70 mph in 5th. As I said before, VTEC doesn't create instant power - it increases the airflow when it's needed most in the engine. If the engine requires airflow at that engine speed, REGARDLESS of what speed that car happens to be at in 5th gear, then VTEC will be activated.
Illustratation: Activating a DOHC VTEC at 1,000 RPM will open both valves extremely wide which allows more airflow, but flow velocity is decreased - less air will rush into the same space during the intake stroke - and low end power is LOST, not gained.
The point is, and maybe this is nitpicking what you said, but VTEC is set at the point that our engine's require, not that gearing dictates. I think the "is VTEC open in 5th gear, if so then it probably doesn't activate that low" argument is moot. Besides, does opening another intake valve on the highway instead of only one really affect gas mileage so much? Gas mileage is more a function of pedal position than RPM or valve opening at that engine speed or any engine speed.
Has ANYBODY asked a Honda technician what RPM we switchover at? It would save all this time theorizing...
Originally Posted by psychotic_z
So it's true - you ARE retarded! Hah, low blow... just playing.
I did say all K's have 5 speeds, but my point for that was that they have a lowwer RPM at 65 mph than the auto civic and for that matter even the 5 speed civic. Yes I know some like the RSX-S have 6 speeds, but that will make the RPM even lowwer at 65 mph. My point is that all K's have at least 5 gears. I forgot the "at least" part though, that's my fualt.
i didn't even bother reading pages 2 and 3...but majority of 1...and just to let you know, we have something called a 3-stage v-tec, the vtec kicks in THREE times!
http://auto.howstuffworks.com/framed...whatsvtec.html
" All the work Honda has done on the VTEC mechanism are combined to make the 3-Stage VTEC system. It is not a rumor, the engine exists: D15B. The engine is used in Honda Civics in Europe and Japan. In short, it combines VTEC-E and SOHC VTEC to get both extraordinarily good RPM fuel economy, and excellent high RPM power. The D15B is a 1.5L engine that is capable of about 54mpg and is rated for about 128HP."
We do not have D15B's nor are they in the US.
Turbos, Engines, Chassis and Suspension Tech
Neat. Now go sit in the corner.
I took the time and put in a vtec light from the diy forum and my vtec doesn't kick in till 3,300 rpm when like 1/4 throttle. It does come on a lot sooner when under hard acceleration. I agree with a lot of people that our motors suck and that we have vtec-e engines.
Once you go Black on Black, You Never Go Back.
holy ****, first off i didnt read pg 2 -
but my 2 cents are that i have a Vtec light and i ran it off the wire from the ECM, and yes, mine was kicking in at 2800 like clockwork.
some of these kids on here have no clue what they are talking about, but thoes who do, thank you for the info.
Actually several things can be done to improve the engine. But it's up to who and what we want to do.
One basic idea without getting into turbo/FI is the air path. Turning a lot of air in a curve dramatically reduce stagnation air pressure(that's what all kind of sensors see) getting into combustor. Our intake manifold has a big 270 degree turn. A turn creates all kind of mess within the flow, boundary layer, friction, etc. Worst case is that the high pressure/low velocity flow actually stops at the walls of tube and all low pressure/high velocity flow is in the center(boundary layer theory). Then during the turn, these two flows interact with each other, causing seperation of flow. Eventually, it will create rotations(recirculation) along the wall, which means it has created negative force with respect to upstream flow direction. Now it becomes a mess and it isn't doing any work in the flow(and energy is low too, you know that when the gas is burned in combustor).
One thing can be done is to get straight intake manifold with the filter sitting directly on top, but controlled in flow direction(cut a port on the hood, may be?). It should help to restore some pressure loss which will in turn raise the compression ratio.
For power, get intake manifold as short and as straight as possible. For fuel economy, slow down and restrict the flow.
No the EX does not have the vtec-e system.
Key points to the vtec-e engine are:
1. reverse cyclic flow pattern in the engine to better aromatization the fuel
2. the flow pattern in #1 allows the engine to run super lean, EX motors do not, in fact they run rich.
3. less power due to #1 (it takes lots of power to do this, hence net power is down)
4. taller gearing, see the final drives in your Honda handout thing form the dealer (this has nothing to do with the engine, but is always paired with the vtec-e engine)
The vtec engine in the EX does not have any of the features listed above, there for it is NOT a vtec-e engine. IF it was a vtec-e engine, you would get 40+MPG and have about 10-15 less hp.
Yes functioning ram air civic
Not this thread again
VTEC features:
Burn rich
Higher compression(!?)
Modified ECU and MAP
VTEC-E features:
12 valve only operation at low rpm
VTEC-E rockers and rocker arms(exact same parts as the HX)
Two (2) intake cam lobes per cylinder
VTEC is pressure/load/throttle sensing, and max crossover point is 3250rpm
It leans more toward VTEC-E than VTEC. I do believe that some people can turn an HX to an EX with ECU, exhaust header and camshaft swap and still making same power(or within 1% limit) with the EX.
Originally Posted by 4drcivic2k1
"Functional" ram air is significantly more sophisticated than a filter on an intake manifold.
Yeah... but still your closer to functional than most people with their little hood scoops
I can only agree some point on this. I only can say that, EX engine has some VTEC and some VTEC-E features in it.
VTEC features:
Burn rich
VTEC-E features:
VTEC features:
Burn rich
VTEC-E features:
No, there is a huge difference. The VTEC systems are the same, but just haveing VTEC doesn't make it a lean burn engine. The lean burn engine has been around before VTEC, see the civic CX. VTEC was simply added to the lean burn so that it could have a little more power, the old lean burn engine was at 70hp. GOta run to class, try to explain more later.
Anyway, you are missing the point that the VTEC-e engine runs lean, leaner than a normal engine can because of the flow pattern in the cylinder that is only characteristic of the lean burn engine.
But VTEC was added to the lean burn engine, so yes, the top end (looking in from the valve cover) is going to look the same. So why would the rocker change? They both still have to have valves. Both have same compression ratio, no big deal there.
You can put an HX ECU on an EX and not get much power loss, but all you have done is lean the engine out, to the point where it might even knock unless you swap the heads from an HX (Because the ports are rifled and valves are slightly tilted, and good luck getting an EX head to do that). I’m not 100% sure, but I think the cams are different too. To get the good MPG, you still have to change the final drive (HX=3.84 EX=4.41 http://www.hondanews.com/CatID2015?m...43094&mime=asc) and lighten your car.
you guys are all idiots. why don't you just leave the vtec to the ecu and stop f.u.c.king with it. honda made it how it is for a reason. if you are wanting true performance engine, why the hell did you buy a civic. now if you swap a k20 into your civic, that's a diff. story. a d-series will always be a d-series. and yes, put a turbo on mine cause I wanted a little more go go and the tight *** bov. I didn't do it thinking my d-series SOHC would own down cars with engine way better than mine. props to gearbox and caorndorff cause they didn't get into a f.u.c.king spat about VTEC!
We are talking about the difference in the lean burn VTEC-e engine versus the normal VTEC motor, nobody is screwing with VTEC or Honda’s stuff or even talking about performance. Please don’t just flame when you not even clear what we are talking about, or at least look at the dates and see what is be discussed today as opposed to 3 months ago. Someone simply ask a question on here and we are discussing it, they where smart enough to at least ask it on this thread instead of making a new thread.
Ashho-san 7thgen Ninja
Whoa. thats alotta stuff to read and try and analyze. I know with my car, i dont feel any thing different in the 2500-3500 range. However, at around 4200, i feel and hear a noticeable difference in the car.
Is buying a VTEC controller worth the effort, or would i just be asking for a lot of trouble and headaches?
Hummmm... Gearbox has one on his car and I think he dyno tuned it too, so he probably knows better than me. But from what I've read, unless you have some major change in your car, like turbo or built motor (i.e. high compression pistons and cams ect.) it really doen't do much for ya other than maybe a couple of hp, just what I've heard.
I don't use the vtec part, only the a/f, which gave me 2whp more after tuning. Best to leave vtec stock. Oh and btw, when I priced out my car in 2002 online, the honda site said the engine was vtec-E for my EX.
