The D17 VTEC controversy (solved).
#32
Rep Power: 244 What would be the advantage of VTEC engaging at 2500? Minor fuel economy advantage at low rpms? If VTEC engages at 2500 and is almost always engaged, then what is the benefit of VTEC?
#35
Rep Power: 0 I hear a sound change and feel the kick at 2500 rpm full throttle. Got an Injen CAI but the lower part broke so using only the top part(but it sounds better than using both parts)
#36
Originally Posted by aznboysrfr
well ... that's what -I've- been saying since the beginning ...
K20a3 vtec is the same as our vtec ... the only difference is that we have only one cam. vtec engages at 2200 rpm under hard throttle, up to 3000 under light throttle. same as the k20a3 ... http://www.hondata.com/techk20general.html
if you check out their vtec cam, it looks very similar to our vtec cam
Nope not true, well mostly not true. The Kseries motors have far more ocmplicated cams than the d's or B's. What you ment to say is the D's work the same way as the B's, but with a single cam and VTEC only on the intake.
K series have VTEC-i, the i (which stand for intelligent I think) means the cams can change phase too. Let's not get into that since that adds a whole new dimension to VTEC. Long story short, while VTEC-i does change camm lobes on the VTEC valve, it does ALOT more thanj ust that.
But becasue of the phase change it can have a much wider range in which it can engage or disengage the VTEC, far more complicated, so the engeagment points will not be the same.
***Added: Also all Kseries motors have 5 speed mated to them which means at 70 MPH your RPM is around 2200, so if you have such a low idle, you can still get good MPH at normal speeds with a lowwer VTEC point. Honda will set the VTEC so that during normal highway cruising speeds the VTEC is on becasue more air=more gas, thats just a stupid idea. VTEC is for added power.
#37
Rep Power: 294 As for the point it engages, not sure, I do know the older d16's where suppose to enage at 4500-4900 RPMS.
#38
Originally Posted by 82801BA
Increase your horsepower at mid rpm, while providing excellent low end fuel economy. That's what the EX is for.
Lets see, at 60-70 MPH, I'm guessing you are not in the low end of your RPM range, probably around 4-5,000 RPMS? Why would VTEC be engaged? You will be using more fuel if VTEC is on, more air=more fuel.
#41
Originally Posted by Sweet2K4EX
Well, I have a CAI and catback (2.25)...I feel the slight kick around 2500 but that only feels like some lag around 1000-2000...the big kick of horsepower is at 4500...
Like I siad, this may not be what happens at 2500 RPMs, but it might be. Honda has a wierd intake manifold on the D17, not sure what that does to this effect.
#43
When I am crusing around 60 or 70 mph... I am only at about 3500-3800 rpms...so the motor is not using alot of fuel.
#44
Turbos, Engines, Chassis and Suspension Tech
#46
Originally Posted by 4drcivic2k1
Not all K series. I know of automatic K series, as well as 6 speed.
So what K series auto has the 4 speed transmission? My Accord has a 5 speed auto, the CRV, Element, and the RSX all have 5 speed autos. Yeah some have 6 speeds, but that still means lowwer RPM at 60-70 which still falls under my point.
#47
The cams on a K series are no more complicated than those on a B series.
It does indeed stand for intelligent. The cams do not change phase. They use variable cam gears to adjust cam timing relative to the crank angle. This is called VTC. The VTEC mechanism is the same as the b series for all intensive purposes.
#48
Rep Power: 0 The difference is that the K series can adjust the VTC on the fly. The B series cannot. Agreed adjusting cam timing can have an effect on where VTEC should be engaged, which is what the K series ecu is designed to do. Optimize cam timing, valve lift, and ignition and fuel timing to produce an effiecient engine.
#49
#50
Yeah, that was my whole point, teh K series can change cam timeing on fly, hence VTEC should come on at different times, which adds a whole new dimension to this discions. That's all.
#51
You said 5 speed. I automatically assumed manual transmission. I do not believe any of the autos are 4 speed.
#52
Rep Power: 0 I'm pretty sure the way VTEC-e work is....
We run 1 valve per cylinder till 2500 rpm's to give good low end and idle.
Then 2500 to VTEC we run 2 valves per cylinder.
And at VTEC to redline we run the bigger lobe and all valves.
I'm pretty sure thats the way it explained it in a brouchure.
#53
Not quite.
We run 3 valve till VTEC. Then 4 valve till redline. There is no "big lobe."
#54
Not quite.
#55
D16's worked this way. Below is a picture of cam from a D16. You can see each cylinder has 5 lobes, 2 out, 2 normal in, one for VTEC. I haven't see the D17 cams, so I can't say.
The D17 has 2 Intake lobes. Low and High. One valve is always on each, then at VTEC both valves are on the high.
#56
#58
Also save on the extra rocker, and can actually make the engine head/block even more compact than D16.
#59
Rep Power: 0 This makes more sense because Honda manufactures the Civic only slightly smaller than the Accord, but it almost has the same strength of Accord. To keep weight lower, I think Honda made very good weight reduction on engine and transmission.
#60
Accord is 14 inch longer, almost 5 inch wider and about the same height. Remeber this is this is the first Accord that is in the Mid size range. Previous Accord where actually close to the curretn civic, so 98-02 Accords are close to civic. (which is still a comact car.
