CHECK ENGINE LIGHT Questions
Old Jan 12, 2005
Nelly's Avatar
Nelly is an unknown quantity at this point
My check engine Light came on out of nowhere a few days ago, i dont kno why it did, i dont have any mods under the hood. no exhaust whatsoever. the only thing i did was take out the air box so i can hear my vtec more and that was a year ago.. i tried resetting the comp by unplugging my negative line and it worked for a day, now its back on.what does it mean. please help
Old Jan 12, 2005
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
how many miles
Old Jan 12, 2005
get the code read with odbii scanner free at some auto parts place.
Old Jan 12, 2005
R1Style's Avatar
you took the airbox off or the airbox resonator?
Old Jan 13, 2005
streetglower's Avatar
Just because you dont have any mods doesnt mean a check engine light wont come on. You have alot of sensors in the car and items that work off of feedback from the PCM and when signals are interupted or not detected or solenoids fail or sensors, the PCM will reconize this problem and turn on the check engine light with a code. Now like gearbox said, you need to hook up a ODBII scanner to it and read the code and go from there.
Old Jan 13, 2005
Nelly's Avatar
i have about 60k and is a diagnostic test the same as that scan u guys r talking about>?, much thanx guys
Old Jan 13, 2005
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
NO! a Diagnostic is about $50 and not necessarily going to pin point your problem... If the parts/repair shop does not want to read your code for FREE then go somewhere else.
I have seen a lot of stores in my area that are no longer reading codes for free... the bastards. ..
btw good post street... he covered everything I was going to see...
My guess would be it may be an air sensor related to your modification... or just a blown sensor somewhere...
However you do need to get that code read and find out what is throwing the code. It could be something more serious. Even if you can get a shop to read the code and just tell you the code number... you can look it up on the sticky for OBDII codes in this Tech Stuff board. And someone here may be able to help you with that.
Old Jan 13, 2005
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
whatever you do...DO NOT GO TO YOUR DEALER!!! They will charge you $100 to scan. You can buy a OBDII scanner for that kind of money.
Old Jan 13, 2005
Nelly's Avatar
First I Really Wanna Thanx Aeveryone For Taking To Help My Dumb ***..haha, But Quick Quesiton I Got A Chance To Rent A Obdii Scanner But Where Is The Ecu Located On The 7th Gen?
Old Jan 13, 2005
djmota's Avatar
Go to an auto zone parts store and ask them to read your code. They should do it for free.
Old Jan 13, 2005
wonderz's Avatar
wonderz is on a distinguished road
the ecu is located behind your glove box.
Old Jan 13, 2005
Nelly's Avatar
I Must Be The Biggest Dumb ***, I Jsut Went Outside And I Just Found Out That My Gas Cap Has Been Off, Hanging On The Hindge, It Msut Been For About A Week. Do You Guys Think Thats Why My Check Engine Lights On?
Old Jan 13, 2005
4jacks's Avatar
ROFLMAO !!!!!!!!!!!!!!!
dude... reset your ecu, it should go off..
it's on the drivers side mine !!!
Old Jan 13, 2005
Just turn until the cap clicks 3 times. The engine light will turn off AFTER several trips. Your ECU will relearn and reset.
Old Jan 13, 2005
Nelly's Avatar
Lol...i Reset It By Taking The Negative Off For A While Rite?....but A Gas Cap Off Would Cause A Engine Lighht To Go Off?
Old Jan 13, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
OBDII cars will set an evap code if the gas cap is off. Should reset after a few key cycles!!
Old Jan 13, 2005
djmota's Avatar
yup
too funny!!
Old Jan 13, 2005
4jacks's Avatar
Yes you reset the ecu by unhooking the negative for about 10 mins.
which u should do to make sure it's the gas cap, and that someone just didn't steal your gas last night >=/
Basically the fumes in the tank build up pressure that if are not present, it trips a sensor.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
thana
Jun 15, 2020 07:05 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
