question on 04-05 fog lights
Old Dec 12, 2004
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
I found a good deal on the fog lights but it says for a 4-door. Will the 4 door fog lights work on the 2-door? Here is the url http://www.procarparts.com/store-lis...IVIC&year=2004
Old Dec 12, 2004
Allow me to comment. Those fogs that you think are a good deal are really fake replica oem STYLE. They are NOT oem honda made. Honda retails their fogs for $350 and I've seen them go for $250. Now that's a better deal and you get the real thing.
But to answer your question, coupe and sedan fogs are the same thing. The only difference is the illunimation color on the interior switch. Sedan will have yellow green and coupe will have red.
Old Dec 12, 2004
Blahman2's Avatar
to tell you the true, OEM style and OEm make no difference to me. Price does make a difference to me.
Old Dec 12, 2004
Get the replicas then. You can always change the color of the switch light. I opened mine up and wired in a blue led. I strongly recommend getting a few sheets of film from lamin-x.com and putting them on the fog lens. Otherwise, you're gonna have broken lights real fast. It's worth the $20 and you just stick on.
Old Dec 12, 2004
Blahman2's Avatar
How hard is the install?
Old Dec 12, 2004
Blahman2's Avatar
following the guide on http://www.handaaccessories.com/civext01.html would I beable to do it easy?
Old Dec 12, 2004
Well, I had the dealer do mine for $175 because it's cold out and I'm getting lazy But yeah it is involved, and I know on the 01-03 there was some bumper cutting involved and finding a place for the relay. I think the 04 might be easier, and all the harness connections are plug in. So basically you need to install the fog lens and then run all the wiring around and to the switch inside.
Old Dec 12, 2004
Blahman2's Avatar
thanks gearbox, as always your info is only the best.
Old Dec 12, 2004
No problem. Also if you want yellow light for the fogs for better visibility, they sell ion bulbs or Impulse is also offering to mod the lights by putting in a yellow bulb cover.
Old Dec 12, 2004
Blahman2's Avatar
well, lets see how the euro clears go. But I won't have them for a while. Give it a few months.
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
