Sanding plastic?
Old Nov 30, 2004
hustlelikem0fo's Avatar
Sanding plastic?
DOes anyone here know how i can sand that plastic of my AC went/ thing around where the AC switches and radio is so it will be smooth to paint?
first i painted it wihtout sanding it and it came out kinda rough. i want to sand it down so it'll be very smooth so i can paint it again...
i dunno anything about the grit #s and all that junk so if i go to home depot what kind of sand paper should i get?
Old Nov 30, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
http://www.7thgencivic.com/forums/sh...d.php?t=185057
i was just talking about this..
anyway.. i used 400 grit..
you dont want to sand it too smooth or it wont stick at all.. you also need to use paint made for plastic or it will peel off.. also dont sand too much or it will come out totaly smooth looking once you paint it and IMO that looks retarded..
2-4 light coats of paint.. 2-3 light coats of clear coat to protect it..
also remember not to start or stop spraying when yer over the plastic or you will get lil drops that look like hell..
Old Nov 30, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
heres another thing. if you wanna use a paint thats not made for plastics.. buy what is called PLASTIC PRIMER... after you sand it spray that on there.. then give it a fine sand.. then use any paint you want.. another thing is helpful is after you sand the plastic either use and airblower to get rid of all the dust plastics or just wash it in the sink with some soap.. that will help keep those plastic sandings from getting in your paint
Old Nov 30, 2004
Danka02's Avatar
SICCMADE
Danka02 is an unknown quantity at this point
i just redid my fuse box cover and my valve cover thing over again and i wet sanded it down first with #400 to catch all the dust and it came out very smooth, now everything my under the hood matches the car, green is a very hard color to find that matches
Old Nov 30, 2004
againifall's Avatar
Go Team Venture!
danka02... got any pics of yer car.. i wanna see what it all looks like in green
Old Nov 30, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
Eastwoodcompany.com has plastic prep, primer and paint that work great.
Old Nov 30, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
So I already painted my vents and dash but i want to redo it. So should i also use 400 grit or something more course to get rid of the paint already there...?
Old Nov 30, 2004
my question also
Old Nov 30, 2004
Vinnie's Avatar
Originally Posted by HustleLikeM0FO
my question also
So did we get a clear answer yet?
Old Nov 30, 2004
Civic04's Avatar
Civic04 is an unknown quantity at this point
depending on how thick ypu put the paint on you could proly use 400 all you realy have to do is get the paint that is already on there smooth, use the primer, sand it and then paint.
If you put the old paint on real thick you might want to sand some off. the ony thing you have to take into consideration is how many layers you will have all to together cause it will start to look getto after a while
Old Nov 30, 2004
i didnt sand al of mine off to go a second color.. mines was originally silver.. i just used a fine grit to give it a rough texture and painted it over with the new color
Old Dec 1, 2004
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
You should strip the paint of first with a product at Home Depot
It comes in a bright orange bottle,
You can get a spary stripper, or a liquid stripper
The name is ORANGE something or other, can't remeber.
It will not harm you plastic, and it works like a ****.
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
jsmithe2010
Sep 25, 2015 07:42 PM
ZoSoIV
Sep 17, 2015 07:17 PM
