high idle problems?
Old Nov 20, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
high idle problems?
hey all, i heard that the idle for our cars is supposed to be at 700rpm +/-50. my car idles over 800 usually, sometimes at 900. so i searched and found gearboxes post about how to adjust idle, unfortunately it didnt lower mine. the only thing i could do was raise it, so its as low as itll go. and ideas on how i could lower it down to around 700?
Old Nov 20, 2004
If you can't do it manually, either there is a faulty sensor (iat, etc.) or your throttle cable is too tight (if you tightened it).
Old Nov 20, 2004
yeah i tightened it and thats what i thought it was at first. so i loosened it past even the normal tension (because i loosened it bit by bit but the idle was still too high). but the rpms didnt change. any suggestions what i should do?
Old Nov 20, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
try to loosen more on the cable, because that's how i adjust mine....
try to loosen more and see if that will help
Old Nov 21, 2004
i dont think i could loosen it anymore, i actually loosened it as far as it would go and left it like that just to make sure that wasnt it. car was still idling over 800.
Old Nov 21, 2004
jdm_bb's Avatar
than you might need to bring your car back to the dealer and let them check it out.
Old Nov 21, 2004
alrighty ill bring it to them, thnx.
Old Nov 22, 2004
IDQcivic's Avatar
IDQcivic should not be trusted
is your car fully warmed up? My car idles pretty high when its cold, try readjusting everything once you get your car's temp up to normal, maybe go around the block a few times, then adjust it...
Old Nov 22, 2004
yeah its warmed up, ive driven like 20 miles and it was still high. but today it was wierd cause it was idling right around 750. but then later on it went back up to like 900 then back down to like 800. this is for like 10 minutes at a time since i was driving quite a bit in the city.
mikemc422
Aug 9, 2018 05:41 PM
jakeconnor
May 5, 2015 07:30 AM
vtechcivic
Apr 21, 2015 06:58 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
1stcivic
Nov 18, 2001 09:17 PM
