cig lighter wires
Old Jul 22, 2004
blue03civic's Avatar
Pro Skater
Question cig lighter wires
alrite i was wondering.. if i wanna run stuff thru my cig lighter without having to plug it in can i? i took it apart and saw a yellow and a black wire.. is that power and ground and can i just hook up the wires with those by connecting them? is that rite?
Old Jul 22, 2004
civicvtec1ps's Avatar
Search and Learn
What are you trying to connect?
Yea black is ground and yellow is power.
I am tapped wires for s2000 start button and works fine.
Old Jul 22, 2004
Vinh's Avatar
careful....cuz i tap wires into the cig wire and too much current
burned a lot fuses in my car...
i pissed in my pants
Old Jul 23, 2004
Pro Skater
how much things should i be able to connect without blowing a a fuse? im not worried ive already blow some and there not hard to replace but id rather not
Old Jul 23, 2004
jsbush's Avatar
jsbush is an unknown quantity at this point
It depends on how many amps each item draws.
You cig ligter fuse is rated at 15amps i believe. So if you plug in one item that draws 12amps, you'll only have 3 amps left for different item/items. or if you plug in two items that both draw 7amps you'll have one amp left.
SimpleUser
Apr 24, 2021 02:54 AM
Dave1984
Jul 22, 2015 06:10 PM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
