Are there really any hp gain in any engine mods?
Old May 6, 2004
RedEU's Avatar
RedEU is an unknown quantity at this point
Question Are there really any hp gain in any engine mods?
I'm just wondering, with all the cars' ECU being smarter by the generations, I'd heard that it'll adapt to any circumstances, so if all the mods has been done to the car eg. air intake, using higher octane fuel, performance exhaust, etc, wouldnt the ECU just 'adapt' to that & go back to its original setting that was programmed by Honda? Unless the ECU is reprogrammed. Though I believe there are some which would increase in power, but I doubt that the 7th gen's ECU is like that. Am I wrong?
Old May 6, 2004
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
Kinda right and kinda wrong as far as i know. It wouldnt really adapt per say but if it were a large enough mod it would just shut off (or stop working correctly) but small stuff will always help a little but whether adding horsepower or just improving fuel mileage
Old May 6, 2004
zen_master's Avatar
is it true that using higher octane of gas increase hp?
from what i heart and wrote on some amount of threads, nobody ever said that it's true...
the driver should pick octane number 87 because it's designed for use with the compression ratio of our engine.....thus, allowing some higher compression engine like the B series to use higher octane fuel..
now, am i right?
Old May 6, 2004
You're right. Now for the RSX-s they recommend using 89 because of the higher engine compression ratio.
tylerginevan
Apr 27, 2015 12:29 PM
CivicVoz
Apr 16, 2015 08:07 PM
JumpingBean
Nov 12, 2001 05:42 PM
se7en
Nov 12, 2001 10:13 AM
colombianDXcivic
Nov 8, 2001 05:26 PM
