Help with Crimestopper CS880S Wiring
Old Dec 6, 2003
ht380's Avatar
ht380 is an unknown quantity at this point
Hi, I brought the Crimestopper CS880S OEM alarm and needs some confirmed wiring location before starting to install into my 2002 Civic sedan.
The wiring are as below, pls help me with the location of the connection.
1. (+)IGN switch after fuse box (yellow)
2. (+)Pos. Door pin sw. (violet)
3. (-)Neg. Hood/Trunk Pin sw. (bule)
4. (-)Neg. Door pin sw. (green)
5. (-)Neg. Output for car horn (Gray)
6. (+)Pos. Siren output (brown)
7. Battery after 15A fuse (red)
8. Parking lights 10A max (white) - to pos. or neg. of parking light ???
9. (+/-) Unlock input signal (blue)
10. (+/-) Lock input signal (green)
For the details alarm diagram, pls click there or see my attachment. http://www.crimestopper.com/techweb/.../cs880-OEM.PDF
Thanks for the advise.
File Type: pdf
Old Dec 6, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Look on the forum sidebar. Click 'Wiring Diagram'
Old Dec 7, 2003
ht380's Avatar
Just to confirmed again my below connection is correct as below. Pls help me.
--IGNITION black/yellow + ignition harness
-- No idea where to connect, pls advise.
--TRUNK/HATCH PIN red - factory alarm plug *1
--Not in use.
--To siren output came with alarm.
--12V white + ignition harness
--PARKING LIGHTS - blue factory alarm plug *1 or to PARKING LIGHTS + red/black back of the fusebox. Pls advise.
--POWER UNLOCK white/green - gray plug above drivers kick
--POWER LOCK white/blue - gray plug above drivers kick
-Where is the ignition harness located and where is the best place to install the siren??
Pls help. Thanks.
Old Dec 8, 2003
ht380's Avatar
Hi, can anyone help me with the below connection that I have no ideas where to connect. Thanks.
1. (-)Neg. Door pin sw. (green)
3. Parking lights 10A max (white) - to pos. or neg. of parking light ???
Pls also comfirmed for me the below connection are correct. Thanks.
2. (-)Neg. Hood/Trunk Pin sw. (bule)
3. (-)Neg. Output for car horn (Gray)
--Not in use.
4. (+)Pos. Siren output (brown)
5. Battery after 15A fuse (red)
6. (+/-) Unlock input signal (blue)
7. (+/-) Lock input signal (green)
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
