m3 mirrors
Old Nov 17, 2003
PsshH's Avatar
PsshH is an unknown quantity at this point
m3 mirrors
i need help putting in my m3 side view mirrors. can anyone help me out with pics or diy?
Old Nov 17, 2003
ImPulse's Avatar
ask the people in the "Tech" section
Old Nov 17, 2003
Vinh's Avatar
the wiring or the actually installing?
Old Nov 17, 2003
cosmo's Avatar
cosmo is an unknown quantity at this point
For power windows
1. Removing the tweeters:
1. Pull on them until they snap off, you can leave them dangling, they shouldn't get in your way
2. Uninstalling the mirror:
1. get a 6mm wrench(If I remeber right) and remove the 3 nuts from the mounting base of the mirrors, the bottom one can be kinda tricky but you can hold it in the wrench while you take it out (balance is key)
2. unclip the electronics from the mirror, the clip will still hold the mirror and thats why I saved this for last.
3. Wiring:
1. remove the end from the factory wires that come up through the door
2. strip each wire: M3's and the original factory one in the door
3. twist 2 of the wires together and test the controls on your power window switch. Do this until you move the arrows on the control and the mirror will function accordingly.
4. a) repeat step 3 until you have it functioning correctly and mark down on a piece of paper which wires go with which, then untwist the wires and pull them through the hole for them in the door
b) sodder the wires together
5. after you figure out the which wires go with which, you can do the second mirror with ease
2.Reinstall:
reverse steps 1. and 2.
Hope you understand, if you have any questions feel free to ask
Old Nov 17, 2003
PsshH's Avatar
the problem is the stock bolts dont fit the after market m3 mirrors. the stock ones are too small for the after market mirrors. HELP!
Old Dec 28, 2003
Whelan's Avatar
Whelan is an unknown quantity at this point
I went to Home Depot and picked up some #13 1-1/2" long hex screws and they worked fine.
Old Dec 28, 2003
Toca's Avatar
Toca is an unknown quantity at this point
yeah you need to rig this part up.. I used wood screws it worked. you need to make sure its thik enought to bite but not break the plastic
Old Dec 28, 2003
Dr5D's Avatar
I believe my stock screws worked..... but its a bitch to take off the door panels to get to that last bolt
Old Dec 28, 2003
IrockCivics's Avatar
ITS VERY EASY TO PUT, I TOOK MINES OFF A COUPLE OF DAYS AGO, AND SOLD THEM FOR $20.00
Old Dec 28, 2003
Drkstalkerr's Avatar
Drkstalkerr is an unknown quantity at this point
stock worked for me, door pannels were in the way. i had a friend help me,i pried the pannel off enough for him to get the socket down there for the third nut.
Old Feb 12, 2004
DJZeratul's Avatar
DJZeratul is an unknown quantity at this point
its not that hard to take the door panel off... only 3 screws holding it on the rest is just prying
(not including the 2 screws holding the door lever)
Old Feb 12, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
[/B]
I just did this last week and it was a pain on the passenger side... wire it up, walk to the other side, test it.. then having to do that over and over again until it was right. blah
Old Feb 16, 2004
ziggyboo84's Avatar
ziggyboo84 is an unknown quantity at this point
does anyway one know where i can get some M3 style Carbonfiber mirrors without the led on the side (power mirrors)????? I've been searchin all over and i cant find the m3 style in carbon fibe that are powerd and have no led!
Old Feb 16, 2004
DreamCivic's Avatar
DreamCivic is an unknown quantity at this point
i just want them without the LED, its IMPOSSIBLE, i tried everywhere
Old Feb 17, 2004
ziggyboo84's Avatar
i have found some a while ago on e bay wihtout the led but the were not carbon fiber nor were they powered!!!!
Old Feb 17, 2004
BlackIce's Avatar
BlackIce is an unknown quantity at this point
I just installed mine this weekend. I also had to get new screws for the mirrors since the stock were too small. I am happy with them, but noticed that the faster I go, the louder the wind can be heard in the opening on the mirror. Thats ok, I just turn my stereo up louder is all.
Old Feb 18, 2004
ziggyboo84's Avatar
heheh does anyone know where to hook up the blinker wires too???
Old Feb 18, 2004
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
mine are power without LED check ebay, it took me a good month to find them.
~nick~
Old Feb 18, 2004
DreamCivic's Avatar
someone please tell me where i can get m3 power mirrors, good ones, thanks
Old Feb 18, 2004
BlackIce's Avatar
I just hooked mine up to the front head light blinkers with a splicer, just make sure you get the parking light and blinker wires correct. Not that hard if you pay attention to the wiring.
h4ldol
Apr 24, 2017 08:16 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
carid
Sep 28, 2015 10:13 AM
MichaelLW
Sep 14, 2015 07:15 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
