Fixed the play in my revo SS
Old Apr 3, 2004
  #31
FALKEN's Avatar
Civicforums Junkie
i might have to try this on mine
Old Apr 8, 2004
  #32
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
so you just open the slot up a little bit so the spring sits all the way into it?? I'm kinda lost here but i think this is what you're saying.
Old Apr 8, 2004
  #33
aznsensation18's Avatar
aznsensation18 is just really niceaznsensation18 is just really niceaznsensation18 is just really niceaznsensation18 is just really niceaznsensation18 is just really nice
i hope this **** doesnt happen to me...i hate doing **** over...GRRRR
Old Apr 8, 2004
  #34
FALKEN's Avatar
Civicforums Junkie
i just filed mine...worked great
(theres still a little bit of play in the actual ball assembly)
Old Apr 8, 2004
  #35
civic01vtec's Avatar
i just installed my Revo the other night and i filed it down and it does help alot.
Old Apr 19, 2004
  #36
FALKEN's Avatar
Civicforums Junkie
Originally posted by Drnknmnky13
You need to file away however much gap you have. If you have .5 cm of gap..then file away .5cm of stop. the gap is pretty small..like seriously the distance between these two lines ||. Your could be a little less or a little more though. Hope this helps.
the gap in mine was bigger than this, so i filed more off...is that bad??
Old May 27, 2004
  #37
FALKEN's Avatar
Civicforums Junkie
did anyone else swap-out the REVO spring for the OEM spring??
i did...it has a bit more tension than the REVO one
did anyone use the OEM pin instead of the REVO pin??
i did...it seems to seat better than the REVO one
Old May 31, 2004
  #38
Grey's Avatar
DIY King
I used the OEM spring. The one included with the Revo Technica SS didn't seat right or something. The OEM worked better.
Old Jun 24, 2004
  #39
518's Avatar
518
518 is on a distinguished road
Never noticed a play while in gear since I installed the Grey and Capyoda at the same time. I also used the OEM pin and spring as mentioned by FALKEN.
One thing Im confused about (what else is new?!) is if that if you have a play and you grind it down more, wouldnt it cause to have more of a play since you are making the gap bigger?!
But anyway, I didnt file mine like I said, and I dont have any play while in gear and this shifter feels solid every shift!!!
Old Jul 10, 2004
  #40
zen_master's Avatar
jeez..
i still don't understand how to file the gap..
anybody??
Old Jul 15, 2004
  #41
Toaster's Avatar
Toaster is on a distinguished road
If I understand it right you file down the lower section so the spring will sit farther into the gap at the top.
I recently am having a problem with the pin at the bottom coming out. I was reading this and thought maybe I will replace the pin with the OEM but have recently moved and had to junk all my OEM stuff. Anyone know where I can get just the pin and maybe the spring. Or know how to keep the pin in place. It pops and then there is tons of play. I mean like it is neutral type play.
Old Jul 15, 2004
  #42
zen_master's Avatar
a ha! now i understand!! thanx!
Old Oct 23, 2004
  #43
lewal's Avatar
lewal has a spectacular aura aboutlewal has a spectacular aura aboutlewal has a spectacular aura about
man, someone should email revo and let them know a little filing really improves the play in their assembly...
spoony
Jan 23, 2002 01:16 PM
nongv
Jan 18, 2002 11:01 PM
01civicboi
Nov 23, 2001 03:02 PM
CIVICINJEN
Nov 6, 2001 01:30 PM
