The Little Bolt That Could
Explosivdeeznutz How much you want to bet i know more about cars and engines then you. I work on cars every day i just have never stripped a nut. Sorry i don't know how to fix a fu(ked up nut, my friend stripped it on his car i'm just trying to help him.
Originally posted by ZMan2k2
Go to Sears and get the "Craftsman Bolt out" kit. This works pretty well. It digs into a stripped bolt and gets it off. It makes it's own grabbing points on a stripped bolt. I have the bolt-out and the screw-out sets, and they both work great. It's like $20, but it will save your sanity.
You definitly dont work on cars every day if you have never stipped a nut, and you definitly have never worked on a car before if you didn't know that a torch will heat up the metal and allow the bolt to free easier, and you DEFINTILY DEFINITLY have no idea about anything, trying to JB Weld a socket to a nut...I told my fellow mechanic's, and i had them rolling around for 20 minutes...They said there should be a test to take to be able to post on this message board. I stuck up for you and said everyone learns somewhere....but man...don't try to be what your not. Good luck with that.."bolt"
Originally posted by JBDesign
^think he meant torch wrench not torch as in fire. LOL right? - yeah buddy a torch wrench comes with a monkey wrench too. LoL right? no
Have you got the nut off, or bolt out? I haven't been able to tell if its a nut or bolt by reading this thread.
DAMN just use EZ Out...I had a bolt get the head stripped clean off and was like oh ****! but my father-in-law had easy out and in 2 min the bolt was out! all it is is a small drill bit that goes into the bolt snags it self in and reverses it out! it works brilliant and costs like $7.
Originally posted by xblkcivicx
It's a nut, the bolt itself is in the block. It's a tough spot to hit, but if you have a swivel socket for your ratchet it comes right off.
Sears craftsman stripped bolt removers work wonders. its like a regular socket but it basically wedges its own "teeth" into the nut allowing you to remove it. give it a try.
2002ExCivic
22
Sep 28, 2015 08:29 AM
pilebuck13
Sep 21, 2015 10:45 PM
