need help with install header
Old Aug 26, 2003
runner1738's Avatar
Im trying to take off my stock header , i have removed the 2 bolts on the top of the heat shield, and im trying to get the third but ive stripped it a little and i cant get it off, ive tried wd-40 and i still cant get it off any advice?
Old Aug 26, 2003
prawdigy's Avatar
prawdigy is an unknown quantity at this point
the gator grip.. other wise use a wrench.. and there is 4.. its rite by the power steering pulley.. rite under that kinda.. good luck and wut headers u get.. JUN? hehe
Old Aug 27, 2003
runner1738's Avatar
ive tried wrenches its just in such an odd place and there is little to no room and it seems really stuck on there,i thought there were only 3 for the heat shield, then the ones for the actual header and the two spring bolts, i got a dc sports ceramic since i needed it to be carb legal
Old Aug 27, 2003
runner1738's Avatar
im a little suprised that out of all the people who have replaced their header no one knows a trick or an easier way to get that bolt off, and is their anything else i should know? do i need to replace the bolt if it stripped to much, or is it ok? do i even need it , when i change headers?
Old Aug 27, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
u need an extention.. thats all.. its really easy actually
Old Aug 27, 2003
runner1738's Avatar
i have an extension but with the fan for the raidator right there its a tight fit, i thinik i should have a longer wrench cause i need to apply to much force, ill try it again and see if i get it off
Old Aug 27, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yea try putting a pipe over the wrench for better leaverage (sp).. i usually do that when tryin to 'brake' bolts..
Old Aug 27, 2003
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
I had this very same problem just last week while installing my DC. The trick is to take that bolt off first. This way pressure is lessend on that bolt. If you jack up your car, you can then get under it with some vise grips and pop it off. Spray the heck out of it with some WD40 or something asnd if you still have trouble torch it and it'll weakken/ loosen cause the nut will expand and come off. After that it's a since. took me 1/2 hr. cause of the bolt
Old Aug 28, 2003
runner1738's Avatar
ive stripped the hell out of the bolt, but do i actually need it cause i dont think so with the design of the dc and the hole placements? is there a way i can just break it off and get the heat shield off?
Old Aug 28, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
dont forget to call up honda see how much torq u have to put into each bolt, make sure u use a torq wrench when u do this
Old Aug 28, 2003
Diablo's Avatar
Diablo is an unknown quantity at this point
No you dont need it if you striped it to **** then you are going to have to get some tin snips and try to cut the heat shield of. you might be able to get at it from the bottom. or if you can just bend it back so that you have enough room to get the 4 bolts from the header. and becareful the right side corner one is a pain make shure you get the socket in ther right or you might end up striping it.
Old Aug 28, 2003
JSWhaler's Avatar
no you do not need that bolt, if you pop it off you'll be alright. The rest of the install is easy, that should be your only trouble spot
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
