rev-matching
Old Sep 8, 2003
  #31
clownprince's Avatar
Ricerus Maximus
Or you can just downshift without rev-matching and let your clutch do the work. It will wear out faster but it works.
Old Sep 8, 2003
  #32
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
but that wouldn't save your sychro's at all... for me I only double clutch downshifting into 2nd, and 1st, becase they have such large gaps between rpms.
Old Sep 8, 2003
  #33
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
Originally posted by Civic_Si_Veloz
So for rev matching, is it just to reduce wear on your brake pads by passing the work down to the engine? Doesn't this just increase your stopping distance?
I learned to match revs during down-shifting for open tracking. Im sure its useful for autocrossing if the layout allows it. You lose previous time and traction (spinouts are not fun) if you shift before the tranny and engine catch up.
Doing it during normal driving is OK, and is good practice. But ultimately all you are going to do is wear out your clutch. I suggest using your brakes if you are only using it to stop/slow down your car. It's alot cheaper to replace your pads then to replace a pressure plate.
Old Sep 9, 2003
  #34
Civic_Si_Veloz's Avatar
Civic_Si_Veloz is an unknown quantity at this point
Thanks for the info Renamazazo!!
Old Sep 9, 2003
  #35
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
Just practice on your daily drive. When you're approaching a turn try not to brake. Step on the clutch, match the speed of your RPM by giving it some gas then shift to whatever lower gear you wanna go to (usually 3rd or 2nd) then release clutch.
Now one question, is it bad to give it gas while in a gear and having the clutch pushed down? Isn't like as if it was in neutral???
Victorious
Jan 28, 2011 01:17 PM
dfminc
Sep 15, 2007 12:00 AM
gelshmoff
May 14, 2003 01:12 AM
