power source???
Old Jul 11, 2003
02civsi's Avatar
02civsi is an unknown quantity at this point
power source???
Hey all,
I was qondering if anyone knew where i could steal some power from in my 02 si. I couldnt find the interior light fuse and the fuses seemed too small to wrap a wire around anyway. Any suggestions on how to hook up a button?
Thanks
Old Jul 11, 2003
Fern's Avatar
The Greatest
Fern is an unknown quantity at this point
What about splicing into the interior light wires? or into the wiring for the cigarette lighter??
Old Jul 11, 2003
02civsi's Avatar
Thanks, i tried to do it quickly last night without my owners manual, so when i get a chance to go at it again ill try going through the lighter. If anyone has done anything like this can you post a reply so i can talk to you.
Thanks again
Old Jul 11, 2003
Devst8n's Avatar
Devst8n is an unknown quantity at this point
hey 02civsi
I did a splice into the wiring for the cig lighter and it works great. It has a fairly beefy wire (for factory) and should be able to power anything up to 10 amps easily. Just remove the center console and the bolts that are hidden underneath the cig lighter. You can buy a tap in splice or just peel back insulation, solder and shink wrap. I use it for the turn on for my amps as I like the look of the factory deck. It is switched so make sure whatever you are powering doesnt need a constant supply.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
BootyDo
Jul 26, 2015 10:38 AM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
