Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
IMA Battery balancing
Old Jun 26, 2020
Rh11688's Avatar
Rh11688 is an unknown quantity at this point
Hello,
Has anybody done any battery balancing on the high voltage battery if so can you give me some advice please and what equipment you used thanks in advance
Old Jun 20, 2021
james wang's Avatar
james wang is an unknown quantity at this point
Re: IMA Battery balancing
To do this, you need a power supply for charging and a discharger. You can use whatever you want. The discharge current is about 5-15a. If you have these, you can charge and discharge each rod several times, discharge to 6.6v, charge to 8.6v, and finally discharge all rods to 7V for installation
Old Jun 20, 2021
Rh11688's Avatar
What sort of charger/discharger would you recommend
Old Jun 20, 2021
james wang's Avatar
The charger can use the power supply, 0-30v5a is enough, the power supply can adjust the voltage and current, and the discharger can use the car air pump. If you already have it, you are lucky. If you don’t buy one, you can still inflate it.
Dorval Andre
Electrical
May 6, 2015 02:33 PM
gearbox
Nov 19, 2011 09:59 PM
ty77064
Apr 30, 2007 11:31 AM
Roosbok
Sep 1, 2005 10:04 AM
iluvbritney
Apr 3, 2003 09:45 PM
