Honda Civic Si Forum Honda Civic Si Forums - Come here to talk all about the venerable Honda Civic Si, both new and old. Threads or posts about the 2006 Honda Civic Si should be put in that forum.
launching 07 si question.
Old Nov 29, 2006
imported_Nick's Avatar
imported_Nick is an unknown quantity at this point
Ok, so I was talking to a friend today about getting the best launch off the line, and he said that if you have it in gear while your stopped and floor it all the way with the clutch in, that it wont redline, but stutter around four and a half grand, so you just drop the clutch.. I cant remember what he called it, but I wanted to ask someone who would know more before i tried it. Thanks
2007 civic si
Old Dec 5, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
yea.. it's a honda feature... it's actually too low of a rpm for a good launch.. there's a way to disable it, but idk on the new civics
Old Dec 6, 2006
blue00si's Avatar
blue00si is an unknown quantity at this point
4500rpms is a great rpm to launch most hondas unless your boosting...you launch much higher than that and you will wheel hop and wont hook up the power.......this is how you launch
first put it in first gear and keep clutch depressed and bring your motor to desired rpms...in this case about 4500rpms...then when your ready to go release the clutch and do yo thang if done properly you should launch good but trust me 4500rpms is plenty high and possibly too high for stock tires and suspension...if you has really sticky tires or slicks and good suspension setup and or traction bars then you probably could luanch higher and benefit from doing so
Tedverseti
Apr 23, 2020 01:45 PM
IronFist
Sep 25, 2015 07:13 PM
pilebuck13
Sep 21, 2015 10:45 PM
99BoostedSi
Sep 7, 2015 04:49 PM
Jul 12, 2015 11:54 AM
