Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
idle issues.... need help!
Old Feb 9, 2010
rbkwhitey's Avatar
rbkwhitey is an unknown quantity at this point
I have a 92 civic hatch. Manual trans. When the car is idling at a stop light, the rpms rev up and down. It seems to get worse as the engine heats up. I cleaned the IACV and it still idles the same. Any ideas???
Old Feb 9, 2010
nvrfstenough's Avatar
nvrfstenough is an unknown quantity at this point
Re: idle issues.... need help!
if your check engine light is on you can check what code its throwing
Old Feb 9, 2010
usually a tps sensor that is not calibrated properly will cause idle to fluctuate. you can try to reset it using a multimeter to the correct voltage (see haynes manual) but its easier to get a whole used throttle body with sensors and swap it in. i dont think they cost more than $50 if you check ebay and junkyard and its easy to change. just be sure to get the correct type for your car auto or manual trans.
Old Feb 10, 2010
rbkwhitey's Avatar
I will try swaping out the throttle body. Thanks for your help!
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
2.0.0.2
Sep 14, 2015 06:38 PM
MichaelLW
Sep 14, 2015 07:15 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
