Dumb female question
These are the moments I wish I was a man. No laughing, ok?
I have a ’97 Civic LX (1.6L v4). Less than a week ago my mechanic just switched out the tranny with a salvaged one. When the car shifts from 1st to 2nd gear, there is a soft thump...just like someone hit the tow hitch with a 5 pound rubber mallet. The other gears are fine. I can live with this, unless it means that the "new" tranny is on its last legs. Any thoughts?
Re: Dumb female question
You can check the fluid level easily.
While you are doing it take note of the fluids condition (it should be a light color and not dark)
The other thing you may try if the level is o.k. is to have an ATF service, most likely a drain and re-fill with only Honda brand fluid.
eh, the problem is alot of shops dont know what theyre doing. we used to have an old ford taurus with 100k miles (for that car, its pretty much dead). the trans went out, and we went to a pretty well known shop with 2 yr trans warranty, well we kept having all sorts of problems with it clunking between 1-2 gear shift. they said its normal and better to have it shift hard instead of smooth, so we kept driving. few months later, it totally died. they rebuilt it, few months later it died again. on the third trans, we finally gave up and quickly sold the car for almost nothing. did the mech use a honda trans on yours from a low mileage salvage car? or rebuild your old one?
hopefully the mech used honda ATF in the honda trans otherwise anything else will cause hard shifting. im betting 99% they do not use honda fluid unless youre at the dealership. thats prolly the issue. our 92 accord family car had some gay aftermarket ATF from the store and shifted like it was about to fail. i did a drain and refill with honda fluid and its been shifting smooth for a year now.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Supamann
Aug 31, 2015 02:14 PM
Palmetto77
Aug 21, 2015 09:22 PM
martinsmartin
Aug 15, 2015 07:34 PM
NoobyKid
Jul 13, 2015 07:53 AM
