What is i-vtec SOHC?
Rep Power: 193 What is i-vtec SOHC?
Okay I know and have driven i-vtec DOHC and regular SOHC (LX) but never really heard of i-vtec Sohc nor vtec Sohc.
What is the difference between the two, and wud someone happen to have pix of this engine?
I searched google but didn't really got a clear answer.
Re: What is i-vtec SOHC?
I can't think of a car that has it, but...
to answer your question,
-non vtec is and engine that has fixed valve openings.
-vtec is an engine that uses oil pressure to engage secondary rocker arms to a more agressive cam lobe and thus changes the valve openong.
-i-vtec works much like the vtec system, but also uses the computer to adjust the ignition timing as well as the valves for improved performance.
dohc can work the same, or the vtec may turn the intake cam to adjust the valve timing...depends on year and model.
hope this helps.
hope this helps.
danace99
10-17-2015 02:51 PM
Amulon
08-18-2015 11:03 AM
jwalkerck1
08-17-2015 10:03 PM
darwin-t
08-15-2015 10:51 AM
Bounddyy
19
07-20-2015 02:42 PM
