Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Cleaning the engine
Old Mar 5, 2006
CG99's Avatar
CG99 is an unknown quantity at this point
Cleaning the engine
I have alot of old oil and dirt just sitting on and around the engine and belts etc.
What is the best way to get rid of this grime?
Old Mar 5, 2006
Darth's Avatar
Darth is an unknown quantity at this point
Degreaser
Costs $2 for a spray can of the stuff and its great. Just cover your alternator and other electricals, spray the motor with degreaser then hose it off.
Old May 14, 2006
CG99's Avatar
Thanks darth, sorry for my delay in replying.
I will try this, its getting worse, i think i have a few oil leaks i need to sort out
Old May 15, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
20 bucks says your valve cover is leaking.... unless of course youve replaced that gasket already.. this is very easy.. i love doing this job for people because i only charge about 10 bucks, so they arent out much money, and it's SO easy that i make 10 bucks on 10 minutes.. both ppl come out on top and one less oil leak to worry about.. let me know if you need instructions.. if so, shoot a pic of under your hood and pm me, i will give you full instructions including most socket sizes...
Old May 15, 2006
Tayler's Avatar
Tayler can only hope to improve
Heads up, make sure you seal your spark plug wires good. When i cleaned out the engine bay in my car i got water in there and had to buy new plugs and wires, same thing happened to two of my friends also. Its easy to stop from happening and expensive when it happens.
Old May 15, 2006
fivespeed's Avatar
fivespeed is an unknown quantity at this point
I would be concerned about moisture being redirected as well. That's not area I freely spray a hose into if i can help it.
Why not contact remove it? Degrease then use rags to get it off. Saves wear and tear on the cleanup down below right?
Old May 15, 2006
imported_Mikey's Avatar
imported_Mikey is an unknown quantity at this point
Post up instructions anyway if you can, its a common problem.
Last time I paid $40 at the mechanic to have this fixed
thana
Jun 15, 2020 07:05 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
SugarRay
Bolt-on Engine Performance
19
Jan 8, 2002 02:55 PM
supercivic01
South
Nov 30, 2001 11:27 AM
