Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
VTEC Question
Old Mar 1, 2006
White2297's Avatar
White2297 is an unknown quantity at this point
VTEC Question
I have searched for this...and no luck.
I have a '96 Civic and i have now gotten some money to spend on the car...I know i want to go Turbo...My question is...Will a turbo do well with a Vtec motor? Because I cant decide between the B18B(Non-Vtec) or the B18C because i have been told by numerous people that the Vtec system cant go haywire with a turbo on the car...now i know that everyone will tell me to go with the B18C since it is a GSR motor and has a few more ponies, but i also dont have pockets made of gold either...if you know what i mean.
Please enlighten me on the knowledge on Vtec and Turbo combinations Oh Honda Gurus !!!!
Thanks,
White2297
P.S. Yes I know about putting in forged internals to run bigger boost settings.
Old Mar 1, 2006
Tayler's Avatar
Tayler can only hope to improve
www.evans-tuning.com
Forums, look at the dyno graphs and look at some of the numbers they are putting down with a b18c1 or b18c5 motor. Look at there setups and ask them questions like, how much did it cost, what is good, bad and whatnot.
Old Mar 1, 2006
imported_Tricky's Avatar
imported_Tricky is an unknown quantity at this point
The VTEC head flows better so is well suited to a turbo.
You might need to upgrade the cams to something with a higher lift.
Also your compression ratio will be higher to what is normally suited to a turbo engine, so you'd be limited to how much boost you can safely run.
Old Mar 3, 2006
GoneIn60's Avatar
GoneIn60 is an unknown quantity at this point
Yes i agree with Tricky Vtec is a good configuration with a turbo especially when you buy a Vtec controller so you can control when you want ur Vtec to kick in. As far as motor I'd get the Non-vtec motor and swap in a head from a vtec engine that way you have the low compression and can run more boost. You can usually find used head's pretty cheap on forums, ebay etc.
Old Mar 3, 2006
Great idea!
No point running higher compression when the head from a vtec is compatible with a non vtec.
Old Mar 5, 2006
anteater's Avatar
anteater is an unknown quantity at this point
It wont last long on a high compression motor anyway.
People cant control themself and often wind up the boost, unaware that a high comp. motor can't handle it.
civic98?
Aug 13, 2015 01:32 AM
gmiguel
Jul 30, 2015 10:52 AM
Smokahontas123
Jul 22, 2015 10:07 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
NoobyKid
Jul 13, 2015 07:53 AM
