Building solid motor mounts
Old Mar 23, 2018
Fatcatter01's Avatar
Fatcatter01 is an unknown quantity at this point
Has anyone ever built a solid set of motor mounts to bolt on car will be drivin on a rough dirt track at high speeds and rubbin is racin in these races was curious if it would be more likely to break something thanks
Old Mar 23, 2018
Re: Building solid motor mounts
I have with my OEM 2002's mounts. I didn't quite fabricate my own mounts, but I modded my OEM mounts to be solid poly mounts instead of more flexible rubber
I didn't feel like shelling out the dough for replacement mounts, so I bought some DevCon Flexane 80 and filled my failed front and passenger/tranny mounts. Comes in 3 hardness levels: 60, 80, and 94 (softest to hardest). On my old mounts, the bushing the bolt went through could pretty much be pulled out once not bolted in. They never failed after the fix, and I rocked those mounts for 6-7 years in (mostly) dry desert vegas heat.
https://www.civicforums.com/forums/1...or-mounts.html
Pics in that thread don't work anymore, and when I bought the stuff, it ran me $30.
Now, price for that stuff is like $50 on amazon Now, price for that stuff is like $50 on amazon
Basically, here's how I did it:
1) Pull mount out
2) Make a cardboard backer for one side of the mount (to keep poly from dripping out) and attach/seal with with tape (I used duck tape). If your mounts are busted, make sure the cardboard backing holds the bushing in place where it needs to be. If you're working with in tact mounts, just make sure the cardboard keeps urethane from flowing into that bushing.
3) Set the mount so it's level, and mix and pour the poly mix until it's flush with the non-cardboarded side. (repeat for other mounts)
4) Allow to cure for 24-48 hours. Cut off cardboard/tape backer and trim as you feel necessary with a razor blade.
5) Reinstall mounts on car.
6) Happy dance.
p.s. I think the 1lb kit was good for 2, maybe 3 mounts.
193drtelco
Sep 8, 2014 09:17 PM
defining
May 31, 2014 09:53 AM
briannbii
Sep 21, 2012 11:28 AM
Crackhead79
Feb 8, 2005 06:51 PM
shnivic
Apr 28, 2003 01:38 AM
