Best Grease for Coilover Binding?
Old Aug 29, 2012
krudmuphin's Avatar
To anyone else who experiences problems with front coilover springs binding and popping, what grease do you recommend for the bearing mounts? I can't exactly remember what I used last time but I used the last of it already.
The grease I used before to stop the binding lasted about 6 months... is that typical? Or is there a grease out there that will last much longer? Whatever it was that I used before worked very well while it lasted. But it's a pain to drop the springs down every couple of months for a simple lube job...
Old Aug 29, 2012
lowlife9's Avatar
Re: Best Grease for Coilover Binding?
what coils do you have ??? maybe try something like this http://www.jegs.com/i/QA1/122/7888-109/10002/-1
as for grease try this http://www.amazon.com/Royal-Purple-0.../dp/B002KCWWFC
or this
Amazon Amazon
Old Aug 29, 2012
krudmuphin's Avatar
I have TEIN Street Basis coilovers. They come with two anodized bearing plates, but no actual roller bearing. Do you think that thrust bearing kit would fit in between the plates? Those bearings would need lubricated as well and I'm assuming with the same product?
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
aaronmechanx
Sep 14, 2015 08:45 PM
