v-tech burns oil -- Solution?
Subscribe
Dec 30, 2011
My car burns a little oil in v-tech, is there any fluids you guys could recommend to prevent this from happening? Thanks
Reply 0
Dec 30, 2011
Re: v-tech burns oil -- Solution?
I don't think your issue is going to be fixed with any fluid. There is a service limit of how much oil is acceptable to burn in x amount of miles, Hondas limit is probably a quart every 1000 miles or so, look into it and if your within the limit i wouldnt be to concerned
Reply 0
Dec 30, 2011
most likely you need new valve seals
Reply 0
Dec 30, 2011
You can use a little higher viscosity oil.
Reply 0
Dec 30, 2011
The car has 160k + on it, thanks for the advice. Ill look into getting new seals.
Reply 0
Dec 30, 2011
If it doesn't burn much, don't do it. Burning a quart, say, every 2500 miles is fine.
Reply 0
Dec 31, 2011
Pour more vteck fluid in. They are having an end of the year sale on them at the hounda dealershit
Reply 0
Subscribe
