Honda Civic 2001 LX Sedan
Old Dec 27, 2011
jdawgzcivic's Avatar
jdawgzcivic is an unknown quantity at this point
I have a Honda Civic 2001 LX Sedan and I don't have the manual anymore. I usually go to the dealer for Oil change but decided to do it myself and save some extra cash.
What is the amount in QUARTS that I should put back in when I put in new Oil?
I greatly appreciate any feedback and comments...
Thanks!
Old Dec 27, 2011
Re: Honda Civic 2001 LX Sedan
Start with 3.5 qts. Run it, then check and add if necessary.
Old Dec 27, 2011
Ok.. Thank you...
When the dealers do it, do you think it's measured? It seems to be leaking on the gasket and I feel they put to much...
How do you measure and read the measurement from the dipstick?
Appreciate it... Thanks!
Old Dec 27, 2011
MindBomber's Avatar
Live for the Twisties
Pull the dipstick, wipe it clean, re-insert for a few seconds, pull it back out and you will see the oil level. There are two holes, the first is the minimum oil level, the second is the full line, the level should be kept on the second line.
I never measure the oil. I just put in 3.5 quarts and adjust if necessary.
I'm not sure what you mean by leaking at the gasket, if you mean the seal around the dipstick or oil cap, it's probably just spillage.
You should check the oil level and tire pressures routinely.
Old Dec 27, 2011
I take a gallon jug full of oil and pour most of it all over the top of the engine.......
No, I measure 3.5, then check after running it.
vtec92
May 4, 2017 03:20 AM
LionSpratt
Jan 29, 2017 11:07 PM
usajags84
May 10, 2015 08:11 AM
jessicakaybby
Apr 20, 2015 12:11 PM
liljoe
Nov 4, 2001 01:27 PM
