Brake Bleeding with ABS System
Hi there forum land,
I'm in a bit of a conundrum. I recently realized that I have gone 3 years now without replacing the brake fluid, quite a big no-no . In my research into bleeding brake lines to get old fluid out and put new in, I have come across several sources that are very vague about how to go about doing it with a brake system that has ABS
One clearly states that if you have ABS, you need to get it done by a professional. Others state that you might be able to do it yourself. So, I'm kind of lost.
I'm wondering that with my 8th-gen civic lx, can I still bleed the system myself? Or do I need to take a visit to my mechanic? Many thanks in advance!
(I searched through previous posts but I was unable to find anything)
One clearly states that if you have ABS, you need to get it done by a professional. Others state that you might be able to do it yourself. So, I'm kind of lost.I'm wondering that with my 8th-gen civic lx, can I still bleed the system myself? Or do I need to take a visit to my mechanic? Many thanks in advance!
Re: Brake Bleeding with ABS System
try searching harder. there are like 100 threads just on bleeding.
so now that i have said that, here is the answer:
General tip for bleeding all brakes is start at the farthest point from the master cylinder.
but to be honest, as long as you start with one of the rear wheels first, you should be fine.
so this is the general bleeding pattern: rear passenger, rear driver, front passenger, front driver.
bleed that cycle twice. by the second time, you should be completely clear of bubbles.
yet, did u see which civic they specified it for? because the bleeding of the LX/DX/VP civics have NO abs. so bleeding like that would be permissible.
http://www.aa1car.com/library/abs_bleeding.htm
and many many other reliable sites tell you to bleed from furthest. but if u cycle the bleeding process twice, it shouldnt matter too much. the point is to just get air out and fresh fluid in.
thewal is correct, thats what the honda manual states. abs shouldnt matter for bleeding unless you are replacing the unit. there are many methods of bleeding if you search around. the pretty much fool proof way is gravity bleeding which takes most of the day and is a slow process. and every 3 yrs is about the normal change time according to honda.
conspiracy90
Jun 7, 2023 01:01 PM
WaryDriver
23
Jul 22, 2015 07:18 PM
Kyrian
Jun 26, 2015 11:48 AM
rayman7
Jun 20, 2015 09:48 PM
I've had no issues.
