Help!!! Civi wont start or sometimes stalls.!!
Old Apr 13, 2010
Mr Essnce's Avatar
Mr Essnce is an unknown quantity at this point
Question Help!!! Civi wont start or sometimes stalls.!!
I turned the car on yesterday nigght worked perfect. This morning the car wont turn on again. The Check Engine Light came back on this morning and the morning before today. Then around 6 pm I tried to start the car and the car started right away. This happened two days in a row. Car will not start in the morning then It will start at 6 o5 pm. I am going crazy. I ran a test on the ECu got code 8 means tdc failure. Some times I will be dricing the car and the car will stall. I replaced the main relay as well. Please help Im going crazzzyyyy!!!!!
Old Apr 14, 2010
crellyx's Avatar
crellyx is an unknown quantity at this point
Re: Help!!! Civi wont start or sometimes stalls.!!
tdc has to do with the distributor check the wires. u might have to change the dizzy cap. because a tdc error can offset the timing.
CRELLYX
Wild Cranker
427
Jan 28, 2016 06:49 PM
SSMatey
Apr 13, 2015 06:09 PM
Trey
Jan 6, 2002 02:30 AM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
