Car occasionally cranking and not starting
Old 02-19-2010
MegaHurtz's Avatar
Hey, I've noticed lately that on occasion when I try and start up my car, it will just crank and crank and crank and not fire up. When it happens, I typically remove the key, put it back in and try again, and it almost always fires up on the first try. Is this indicative that something might be failing on the car? I haven't been able to tie the problem to any other conditions (such as weather), so I'm pretty clueless at this point. Some interwebcrawling didn't turn up any other information. Any tips will help, thanks
Old 02-19-2010
CraigW's Avatar
Re: Car occasionally cranking and not starting
Have you tried the method of leaving the key at II until you hear the fuel pump stop & then crank it over ??
I have trained myself to do this each time and never once (except maybe when super cold morning) failed to start the 1st attempt.
Worth a try.
Old 02-19-2010
HLC
HLC's Avatar
HLC is an unknown quantity at this point
yea, you've got to let the fuel pressurize. just wait for the fuel pump to kick off, then you're good to go.
CarStuff
12-06-2020 12:52 PM
Trav_02civic
Engine start problems
04-23-2015 08:57 AM
Blaster30
04-22-2015 12:21 PM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: Car occasionally cranking and not starting
