97 LX Transmission Problems - Change or Rebuild/Replace
Old Nov 30, 2009
coderLuke's Avatar
coderLuke is an unknown quantity at this point
Hey all,
I've been lurking for awhile since I've started trying to do my own maintenance on my '97 Civic LX ~150K miles and figured I'd ask for some advice. Right now my transmission makes a grinding noise when going from park or reverse into drive. After driving it for awhile and the engine is fully warmed up I don't notice any sort of grinding noise. From what I've read flushing the transmission fluid at this point is a terrible idea. I've also read in a few places that even changing the fluid is a bad idea.
So I'm hoping to get some input on whether or not I should bother changing the ATF out at this point or just start preparing my wallet for some transmission work. Also, would there be any advantage to replacing my existing transmission versus having it rebuilt? also,
One final question: Looking at the DIY here: https://www.civicforums.com/forums/7...tf-change.html when I fill the transmission back up with ATF fluid do I just fill it where the dipstick is located or is there a separate fill hole/bolt that needs to come out?
Thanks.
Old Nov 30, 2009
Re: 97 LX Transmission Problems - Change or Rebuild/Replace
you fill thru the dipstick hole. and if the fluid is really old, changing it may make it worse. its worth a try, but just prepare yourself for a new transmission. rebuilding is usually more reliable than replacing, since you have everything in the trans looked at and changed with new parts if bad. may want to see if TCI makes a rebuild kit with upgraded clutches.
Old Nov 30, 2009
coderLuke's Avatar
Thank you sir. I'll try a drain and fill this weekend and prepare for a potential disaster.
If I do end up having to do a rebuild I very likely would have to take it into a shop. Any estimates on what I'd be looking at paying for parts and labor? $1500-$2000?
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
sysblack
May 13, 2015 08:55 PM
cruisers10
May 12, 2015 10:46 PM
markp94
Apr 30, 2015 09:19 PM
