Need help with headlights
Rep Power: 183 Need help with headlights
My headlights have turned yellow and I was just wondering if anybody would know and like to enlighten me on how I can clean it...
thanks in advanced
thanks in advanced
Rep Power: 0 Re: Need help with headlights
There are several post on how to wet sand your headlights back to normal, you can also get a thing called Mothers Mag & Aluminum Polish from walmart. I used it all the time on my old 97 Civic. They always turned yellow again after a few months but they look like new when you clean em. Sanding them down is the best way tho.
Rep Power: 188 Re: Need help with headlights
I've had the best luck with Meguiar's Plast-x from Wal-Mart. Its about $4-5 for the bottle and does a pretty good job at cleaning the hazy yellow film. As with other similar products, a slight yellow tint (but no haze) will come back after a few months, but its nothing that another application can't fix.
I've heard and seen pictures of amazing results from wet-sanding but haven't tried that method myself.
Good luck!
Good luck!
Rep Power: 183 Re: Need help with headlights
thank youuuu
I appreciate the help, I'm hitting up walmart 1st thing after work tomorrow
lmaoo
maybe I'll try the sanding sometime too
lmaoo
Rep Power: 280 Re: Need help with headlights
i heard with the meguires' plastic-x, it will work, but eventually the yellow will come back. you'll have to wet sand the headlights to ensure the oxidation (yellowness) stays off.
I bought the plastx and ma headlights came out ok, I guess for best results I'm going to have to wetsand it but I do see an improvement
thanksss
thanksss
meicalnissyen
09-25-2015 12:12 AM
rnaodm
09-21-2015 12:42 PM
shaejb15
09-12-2015 01:02 AM
Bricoleur
09-09-2015 12:23 PM
MamaBear2015
09-04-2015 09:04 PM
