How To Bring Up Error Codes On a 1997 Civic
Old Feb 26, 2009
mharnisch's Avatar
mharnisch is an unknown quantity at this point
Does anyone know if there is a way to bring up error codes on a 1997 Civic without needing a code scanner? I have a 2005 Chrysler Town & Country and I can get error codes just by turning the key "on-off, on-off, on" within 5 seconds and the codes are displayed on the digital odometer. Very convenient.
Old Feb 26, 2009
bakertime's Avatar
bakertime is a jewel in the roughbakertime is a jewel in the roughbakertime is a jewel in the rough
Re: How To Bring Up Error Codes On a 1997 Civic
I'm going to assume it's the same as my Integra. You have to look above the ECU (Passenger side kick panel on the right floor), and there should be a 2 pin female connector shoved into rubber block that just holds it there. Just yank that out and jump it with a paperclip. Then turn your ignition to the ON position and the CEL will blink 1 time, and then blink the code. Long blink = 10, short blink = 1. So for example, long-long-short = 21. If you search online for a list of the codes, you'll be all set (And double check the method I mentioned)
Old Feb 27, 2009
mharnisch's Avatar
Does the kick panel have to be removed? What are the ECU and CEL?
usajags84
15
Aug 19, 2015 03:12 AM
usajags84
May 10, 2015 08:11 AM
Dorval Andre
Apr 20, 2015 05:34 PM
dooner24
Apr 14, 2015 07:51 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
