where is the oil filter
Old Oct 21, 2006
tontonelly's Avatar
tontonelly is an unknown quantity at this point
i cnat seem to find where the oil filer on my 01 civic is at im the kind of guy who just want to find it and know where it is so i wont waste time so if you can help me out thnxs
Old Oct 21, 2006
hwt101's Avatar
hwt101 is an unknown quantity at this point
you might want to take it to an oil change place if you cant find it, but it is on the bottom right side of the engine if your looking into the engine bay, almost underneath the car i believe. im just messin w/you you do need to get under teh car to see it pretty much
Old Oct 21, 2006
Axe Man's Avatar
Axe Man is an unknown quantity at this point
It's on the backside of the engine block tucked up under the intake manifold. You really need to put the Civic on ramps or a lift to see it and to get to it.
If you follow the exhaust pipe down...where it curves and goes straight back look up above it. The oil filter is essentially straight up and sticking out the side of the block.
Old Oct 21, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
^what they said
Old Oct 21, 2006
sl33pyriceboi's Avatar
look in ur manual, it'll show u
Old Oct 22, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
dont do ur own oil if u cant find the filter
Old Oct 22, 2006
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
^werd
Old Oct 22, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
If you can't find the oil filter after more then one minute of looking, get out from under it, get in the driver's seat, and head straight to Jiffy Lube or something of that nature
Old Oct 22, 2006
dalaw's Avatar
Bone Stock!
Honda puts the oil filter in the worst place you can imagine
Old Oct 22, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
Whats wrong with not being able to find the oil filter? Its not located in the easiest place. Telling him to have someone else do it isnt going to help him learn anything.
Old Oct 22, 2006
streetglower's Avatar
its even taken me several minutes to find the oil filter on some vehicles.
Old Oct 22, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
yea my buddy who was helping with my oil change(i was at his house and he insisted) we had a great time gettin to that freaking oil filter. if you are lookin for it crawl under the car and go till the engine stops and u see the intake manifold. you will see the oil filter waving at you. i would suggest gettin like adjustable oil wrenches not the one with the ring and you gotta close it in. it wouldve taken us about 1 min to get it off if we had that tool.
Old Oct 22, 2006
Axe Man's Avatar
TonTon, ignore the negative comments. We were all noobs at one time. Seems some of us forget that. Locating the oil filter is difficult even if you know EXACTLY where to look. You can get a peak at it if you turn the steering wheel just right. That's how I finally found it. Even though I once owned a 5th Gen Civic and I knew where it should be. 5th Gen Civics used an 80 mm filter. And you could change it top side. There was enough room between the intake manifold and the firewall to get your hand in there and reach it. Plus you could see the filter mount between the runners of the manifold. Not so with the 7th Gen. No room between the manifold and firewall plus you can't see the mount thru the intake runners. And 7th Gens use that tiny 68 mm filter. The only way to get to it is from the bottom.
Old Oct 24, 2006
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
I was just wondering the same thing. Already got my filter and everything to do my synthetic conversion, and my luck, cnat find ****.
Old Oct 24, 2006
CenZ's Avatar
PWIT
its in a bad place, the worst is when you do get it off, it just pours all over the place. if i had the money i would relocated it under my hood.
Old Oct 24, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
It amazes me how people think you have to be a rocket scientist to change your oil. Just because he didn't see the filter doesn't mean he shouldn't try. I spent about five minutes looking for my wife's Accord filter from the topside before we bought it, and it is my 5th Honda.
If you can change a light bulb, you can change your oil. Only difference is there's a bolt and a lot of black stuff on your arm...
Old Nov 1, 2006
yamahaSHO's Avatar
yamahaSHO is an unknown quantity at this point
If you look at your owners manual, it tells you (with pictures) exactly where the filter and drain plug is.
mistermenphis22
Jul 13, 2015 04:43 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
stvpagn
Jul 9, 2015 09:59 PM
1khilari
Jul 9, 2015 08:12 PM
CivicsClass101
Jul 9, 2015 11:14 AM
