smoother acceleration
It's about 7200 bc I've gone past 7000 after first gear. I don't think first gear allows you to rev that high but I"ve def hit 7200 shifting to third. I don't do this often but its fun chasing Evos and such on the highway at times lol.
I believe the d17a2 rev limits at 69xx. Every stock civic tach I've seen has been off at higher rpm levels, mine displays around 7100 when the fuel cuts but I remember someone posted their aftermarket digital tach's reading at rev limit and it was just below 7k.
Ya I've heard stock tachs are off but thats what I've seen when I shift at redline. I guess a true dyno would be able to tell, not that any of this matters. Thanks for the clarity though. I was not trying to tell ppl the wrong thing thats just what i experienced.
http://auto.howstuffworks.com/question90.htm
higher octane does nothing for performance, here is what the octane rating means.^^^^^
you only need higher octane if you have a higher compression engine that could cause the fuel to spontaneously ingnite (knocking) b/c high pressure = high heat which = combustion.... so there you go... our engines are designed to take 87 or 86 or whatever, so use it and stop wasting you hard earned cash
sigh...this has been discussed so many times. This is econobox car. it was designed and tuned to run best at low octane gas. Why would they make it run better with higher octane if the car is designed to be CHEAP on gas?
Octane is something to talk about for us guys who can't swap yet (warranty) and dream of having more power. I read somewhere on a thread here that the ECU on our cars will retard the timing if it senses detonation, say for nitrous applications. Would the ECU advance the timing if we are using higher octane fuels? Would advancing the timing help to get more power out of higher octane fuels? I have buddies with mustangs who go to the track, add octane booster and advance the timing for more power? They say it works, what is the idea, how would that work?
the manual for my Ex says i can use 87 Octane OR HIGHER so i've been using Premium gas. i dunno. like i said before, i've been using premium gas and can't seem to go back to 87 cause it's become a habbit now. ohwell.
All I know is if you keep putting that OCTANE booster in your car your gonna kill it. I just like using SUNOCO 87 all the time. If your going to different station, getting different octanes and adding different boosters t6he car is allways gonna be learning. I think my car taut on the same gas station and gas is better and the ECU is used to it for years. Just my .2
mistahlorax13
21
Nov 18, 2015 12:47 PM
Bruce2
Sep 27, 2015 08:45 PM
tropicola
Sep 25, 2015 07:02 PM
dantheman42
Sep 4, 2015 01:10 PM
