Oil
Old Aug 3, 2006
Sam58's Avatar
Sam58 is an unknown quantity at this point
Question Oil
I recently got a 01 honda civic 110 km on the engine.
Is it wise to add a Slick 50 to the engine???
Old Aug 3, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
I would not. Why are you thinking about adding it? If you want to clean up the internals, there are better ways of doing that.
Old Aug 3, 2006
Jrfish007's Avatar
Yup, like ctx said, I wouldn't bother with that. If you really want to clean the engine up internally, tring buying a REALLY good synthetic and running it for a couple oil changes, that will probably be the best thing you can do.
Old Aug 3, 2006
CuRiOuSfIsH's Avatar
Back From The Banned!
Slick 50 isnt a fuel or engine cleaner.... it is used to protect engine internals I believe. It wouldnt hurt to use it.... but it probably isnt necessary. Just do routine oil changes and you should fine.
Old Aug 3, 2006
ctx66's Avatar
I agree with jrfish. If the engine is really bad, which i doubt it is with that kind of mileage, i'd look into a product called auto-rx. Lots of info on it at bobistheoilguy.com.
But if you want something which requires less work, just use a good synthetic like Red Line or Mobil 1. But out of all the synthetics, Red Line is probably best for cleaning properties.
Old Aug 3, 2006
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
if you want to clean up the engine, just run sea foam through it (thats to clean out the internals), Ive heard alot of bad things about slick 50, but like everyone said, a good Synthetic like Redline or Royal Purple
Old Aug 3, 2006
i would only use auto-rx or lubecontrol.com products for the oil and gas. even the honda manual says not to put anything in the engine. all the store stuff is crap pretty much.
emich
Dec 11, 2015 12:20 PM
SidCivic
17
Aug 23, 2015 03:14 AM
CdnRD
Aug 21, 2015 11:42 PM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
