Em2 Civic AXLE Removal DIY 1st one made
Hi im going to show you how to remove both axles from a auto 01 civic ex or manaul. the manual has some less steps
first lift car on jacks and remove wheels
then you see the spring and strut
1. remove the 2 bolts
then remove the big nut in the center of the wheel
you dont have to remove the abs knock sensor but its recommend
carefully hammer out the center
then slide out
by the way this is driver side
then go under car
you see this
remove all the shift linkage cables and covers
hammer the tabs out if the way and remove the screw
then get a crow bar and press out till the axle pops out
BECAREFUL DONT PULL ON AXLE IF NOT POPED OUT
driver side done
passenger side the pain in the ***
remove bolts
remove nut
remove brake line holder and abs knock wire holder or it will tear
tap out like other side
these are the lines i was talking about
with crowbar push out and tada
you done
Please be informed that an alignment is warranted after removing the knuckle
im also makeing a d17a2 engine removal diy sometime this week
BROBO
then slide out
then go under car
you see this
driver side done
remove bolts
remove nut
you done
BROBO
Re: Em2 Civic AXLE Removal DIY 1st one made
Nice work.
Few things: I'd show how to get the axle nut off first (use a flathead to take take the notch out, then use ) and then do the two bolts holding the brake assemble on.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
toastyghosty
37
Jun 10, 2002 01:07 AM
03, 2002, 2005, axle, axles, civic, diy, em2, honda, installation, removal, removing, replacement, transmission, video
Thanks.
