DIY: Input Shaft Bearing
Old Dec 9, 2019
  #61
Colin42's Avatar
Re: DIY: Input Shaft Bearing
But if you're looking for an excuse to buy a hoist....
Old Dec 10, 2019
  #62
BrotatoChip's Avatar
Super Moderator
A couple 2x4's nailed together and set across the strut towers would probably work too.
Old Jan 16, 2020
  #63
M240B's Avatar
M240B is an unknown quantity at this point
Finished up this ISB DIY and the timing belt/water pump DIY but before I put the wheels back on I turned the car on to makes sure everything was working correctly. The vehicle is still on 4 jack stands and I noticed that while I had the transmission in neutral the driver side rotor would spin and the passenger side rotor would not. If I grabbed the lug nuts it would stop. Is this normal? I am assuming that with the wheels on and the weight of car it would not be enough force to go forward. Shifted into first gear but only the driver side rotor would spin, the passenger side did not. I would assume that both rotors should be spinning if I am in first gear. Not sure if I screwed something up.
Old Jan 16, 2020
  #64
Colin42's Avatar
It's normal don't worry about it, it's because of the differential
Old Jan 16, 2020
  #65
M240B's Avatar
Success! Thanks for the DIY never would have attempted if I had not found this.
BlueEM2
Engine DIY
285
Sep 19, 2023 09:35 AM
GolNat
Suspension DIY
May 12, 2022 06:49 AM
dnmacdon
Aug 27, 2016 03:33 PM
Gunner
Suspension DIY
Sep 9, 2012 09:11 AM
MindBomber
Suspension DIY
Apr 9, 2011 03:17 AM
