Trans issue 03 LX coupe
Hi everyone and thanks in advance for reading and responding to my post. I am new to this forum and have found most information to be helpful just can't seem to get a straight answer on the issue I am having. I will try to make this as brief as possible. I recently purchased a 2003 lx coupe which on test drive felt solid and had no issues. But I've noticed that when the car is cold, and when I say cold I mean after not being driven long enough for the engine to cool down, the transmission will shift kinda hard into reverse and then from 2nd to 3rd it will slip briefly and then go into gear. (like it's a manual and will cause you and the whole car to "shift" with it). I did a drain and refill on it yesterday and used OEM fluid and it's still the same. I have read on here people having similar issues but could never find a remedy. When the car is warmed up and I've been driving for a while it doesn't do this at all. Are there any additives that will help with this problem? I have read on here that there were known issues with this year tranny but I don't think honda would do anything about it since it's got 188k miles. I spoke with the previous owner (bought car from a dealer and found the owner on facebook) and she stated she'd never had any issues with the tranny and this is a one owner car. I'm at a loss really.
Re: Trans issue 03 LX coupe
HTH
Well thanks for getting back to me on that. I'll have to baby it until I can afford to have something done. More worried about the timing belt since the previous owner had never had it changed so I'm going to have that done first. I guess for $3k I have to expect some issues.
The flare is minimal really maybe 1 notch on the tach and it's. I have been letting it warm up for a little bit before driving it and that has been helping quite a bit. Do we know why this is happening? I have read a few things on here and design issues or something with the tranny and the internal "strainer". I was looking more towards getting a response letting me know what the possible causes were and maybe how to fix it.
eventually will need to be rebuilt. it depends, but usually excess wear of the secondary clutch, torque converter issues, and clogged internal filter are to blame. hard to say how long but it could last another 50k or more before it wont drive.
Thanks. I'll get with the shop to see how much a rebuild will be and go from there. I am picking it up today from the shop after having the timing belt, water pump, along with gaskets and seals replaced. There was also a recall on the headlight switch that they are replacing and fixing some issue with the seatbelt.
oneheadlight
Apr 29, 2015 11:30 PM
davidpaustin
Apr 29, 2015 02:23 PM
