DIY: Blue LED gauge and dash lights
Old Mar 29, 2005
  #121
JoshEH's Avatar
JoshEH is an unknown quantity at this point
hmm .. im dumb. though in my defense never been in a civic sedan, they just arent as cool. lol. j/k
i'll look around for one, but still gonna try to do it myself. so will look for your expert advice this weekend.
Old Mar 29, 2005
  #122
AlienX's Avatar
AlienX will become famous soon enough
i'm talking bout 03-04 clusters + the only reason urz came out alittle foggy because u used acetone. I used acetone on my last cluster and it foged up also. I used water down acetone ( nail polish remover ) and alhocol which came out perfect.
Old Apr 15, 2005
  #123
benya7thmix's Avatar
benya7thmix is an unknown quantity at this point
if i shave anything i'll screw it up.....
2mm leds? is that right?
--BENYA
Old Apr 15, 2005
  #124
AlienX's Avatar
what is it that you want to shave ? the head of the LED ? if so, you can as long as you sand it flat without hitting the diode inside.
Old Apr 15, 2005
  #125
paradoxblue's Avatar
2mm.. leds come in 3mm and 5mm i havnt seen 2mm before :|
Old Apr 23, 2005
  #126
AlienX's Avatar
dont shave everything...
you will be able to see the leads inside the LED. dont go that far. If you want to put some risk in it and dont have sand paper, you can break the plastic with cutting tool (pliars, ect )
id post more pics, but they are all on the first page. and yes.. 3mm and 5mm... no 2mm.
Old Apr 23, 2005
  #127
ncirom2003's Avatar
...........im still trying to get my dash done for about 2 months now....... just no time, while ive got time to screw with does anyone know how to wire it so the dimmer works cus i dont like it realllllly bright
Old Apr 24, 2005
  #128
AlienX's Avatar
dimmer control doesn't make a big differance. You need to hook up your own pot, somewhere in the range of 0-1000000 ohms. that should be good enough =) but again it depends on your LEDs. You need to do ohms law to find out how much ohms it will take to have 0V under your LEDs operating conditions. Make sure to grab one that is linear also.
Old Jul 7, 2005
  #129
1of_many's Avatar
1of_many is an unknown quantity at this point
http://ledautomotive.com/
This site is what I used and converted all of my lights over to blue LEDS and it worked great. They also include instructions for each kit or offer installation for those who dont want to do it and after doing it I can say it is a pain so it might be worth while.
Old Jul 7, 2005
  #130
ya they're good if you're the lazy type. ook so long to diy it but i ran extra wires and stuff too.
Old Jul 13, 2005
  #131
2slow2run's Avatar
wut time is it now
2slow2run is an unknown quantity at this point
the kit wit the resister i got from ledautomotive is 2 small..i seem to burn them out wit my big fingers..
well i just got the resister at radio shack
is 470 ohms not 470k ohms. it work fine. the 1/4 watt is kinda big so i got 1/2 watt
witch r smaller n been using it since..i guess it thats y mines is not as bright as gearbox so hopefully in the long run after they blow up.. is back to square 1
i forgot 1 of u guys gave me the link to the led.
www.lsdiodes.com all the leds there r 4000 mcd and up N start at $.45 cent a piece
Old Jul 13, 2005
  #132
i only used 2600mcd leds and they're bright enough but still dim in some spots. Still visible at least. I got all radioshack stuff.
Old Jul 13, 2005
  #133
Big Rob's Avatar
I'm taking over!
Big Rob has a little shameless behaviour in the past
I guess that I have a few questions that I have been meaning to ask.
This question is more aimed at gearbox because I remember him mentioning something about it before. What is the main difference in terms of looks between led gauges and gauges wraped with el-wire?
I recently bought a Pioneer Deh-p8600mp and the buttons are a really dark blue. Is there any way to get the leds that same color so that everything is flush? Maybe a tint on the leds and then run more power to compensate for the loss in brightness?
If I want to adjust the brightness of my leds from time to time, is there a **** that I can install that will regulate power or will I have to change the resistors? It would be nice to have access to that type of control while driving. I never was a fan of the factory dimmer anyway.
Old Jul 15, 2005
  #134
Big Rob's Avatar
I'm taking over!
Old Jul 15, 2005
  #135
el wire gives a much more even coverage (light looks like stock). With leds, it will be very hard to get this unless you have alot of leds everywhere. The el matches the pioneer el display. Buttons are harder, because the company uses its own leds (which could be any wavelength of blue). Mine are actually purple. And filtering leds is not good because they get really dim. Easiest way would be to wire through the factory dimmer. The wire for that is the power going to the auto shifter light if you have one. But mine are always a constant brightness. I want them at full brightness anyway.
Old Jul 15, 2005
  #136
Big Rob's Avatar
I'm taking over!
So, if I read this right, then el wire is going to look better because it is more even? If that is the case, then why hasn't a diy been made? If I go that route, then I guess that I can make one.
Is this a pretty good deal for el wire?
http://www.xoxide.com/elwire.html
Old Jul 15, 2005
  #137
i paid alot for mine, got 4 packs $80 total 20ft is all you can fit and its plenty bright. There is a diy done by me in lighting forum sticky. Its called DIY: blue glow needles.
Old Jul 25, 2005
  #138
Whelan's Avatar
Whelan is an unknown quantity at this point
I will be doing my HVAC center console controls, as well as the window controls and the roof/mirror/cruise control lights. I am making them all blue and putting a red light on the Cruise switch instead of the green.
I used 11,000 on my Angel eyes and that was pretty bright. I am not worried about the HU as it will be changed eventually. And my needles will be red.
But my concern is for the odometer on the dash. It will still be that orange color it is now unless someone knows how to change it out?
Old Jul 25, 2005
  #139
nah its too hard. You can pull off the light diffuser and try to clear it, but mine broke. Try and scrape the paint off it so its clear instead of using solvents. Without it, you can basically see right through the lcd. If you clear that piece and put it back, then you could try and put leds behind it. I just left mine off. There's no real need to see at night anyway.
Old Jul 25, 2005
  #140
Whelan's Avatar
What if I removed the plastic cover that has the orange on it ( I assume that is what it is) Then put a piece of colored film over it?
Old Jul 25, 2005
  #141
won't work. you will still see whatever kind of lighting you put, like the shape of a bulb. This plastic piece diffuses the light. You have to use the plastic, so try scraping off the orange on it and replace the piece.
Old May 15, 2007
  #142
civicDave's Avatar
civicDave has a reputation beyond reputecivicDave has a reputation beyond reputecivicDave has a reputation beyond reputecivicDave has a reputation beyond reputecivicDave has a reputation beyond reputecivicDave has a reputation beyond reputecivicDave has a reputation beyond reputecivicDave has a reputation beyond reputecivicDave has a reputation beyond reputecivicDave has a reputation beyond reputecivicDave has a reputation beyond repute
Re: DIY: Blue LED gauge and dash lights
A BIG THANK YOU TO:
MetalViper for providing the pictures to update this DIY article.
He will be receiving a CivicForums T-Shirt, you could too if you send me pictures to update a DIY article.
Old Apr 22, 2012
  #143
blake0844's Avatar
blake0844 is an unknown quantity at this point
Originally Posted by AlienX
If you need any additional pictures or instructions.. feel free to ask..
hey alienX i have a 2002 honda civic EX coupe and the lights are orange but i wanna change them to blue its just da same process???
https://www.civicforums.com/forums/d...s/DSC00033.JPG
because in thiz picture it look like u just plug in the LEDS or do u have to more work on da white plastic to put da resistor ??
ill be waiting for ur answer thanks email : blake0844@hotmail.com
Old May 28, 2012
  #144
concepttheman's Avatar
concepttheman is an unknown quantity at this point
Wow its been 7 years. Im assuming we could just get plug and play from ledautomotive.com now. If this is the case please pm me. I wanna get my car allllll blue.
I dont wanna solder or anything. Its fjnny cause im taking nanotechnology, but didnt take circuits classes yet. Plz pm....thanks. links would be helpful...peace...god bless
Old May 28, 2012
  #145
ledautomotive has a plug and play option, but it doubles the price. I started off the the LEDautomotive kit, then realized I could buy all the components myself for cheaper and have much more extra on hand. I opted for SMD LEDs because the light spread was better and a bit brighter, although they are a bit harder to work with.
http://ledautomotive.com/product.php?id_product=79
voblak2
20
May 4, 2023 02:08 PM
twtron
Apr 17, 2015 12:09 AM
AlpineCivic
111
Oct 20, 2003 07:31 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
sonsonzai
Nov 4, 2001 12:52 PM
