DIY: No More Trunk Rattle!
Old Feb 7, 2010
  #121
incognyto's Avatar
incognyto is an unknown quantity at this point
Re: DIY: No More Trunk Rattle!
HOLY SMOKES about that trunk with the broken metal... definatley a weld job take it to school or find someone that can weld it ... use extra bridging too!! strengthen that thing up !!! hahahaha must have some good boom in the trunk to break it I have an 03 civic coupe and I just lowered the latch and that held back the rattles for my 2 12's... but I just upgraded to 15's and another amp, hollllly crap does the trunk rattle like crazy ... i've lowered the rubber blocks a bit and lowered the latch a bit more and nowhe I'm going to put BLUESKIN (from hardware store similiar to dynamat) all the way around the trunk where the seal will sit basically lowering the entire trunk
Old Feb 6, 2012
  #122
biobot93's Avatar
biobot93 is an unknown quantity at this point
any chance you can re upload the pics? or if anyone could upload some new ones, dont feel confortable after i broke both my drivers side and passengers side kicks putting in my amp...
Old Mar 26, 2012
  #123
TMILLER618's Avatar
TMILLER618 is an unknown quantity at this point
Why are there not pictures here I was looking forward to seeing the finished results
Old May 10, 2012
  #124
yogeshsr's Avatar
yogeshsr is an unknown quantity at this point
hello,
Can someone confirm the rubber stoppers referred in this DIY is part no 10 (74828-SX0-000) from below link?
http://www.hondaautomotiveparts.com/...ID&vinsrch=yes
what exactly is trunk latch lock?
my trunk makes annoying noise while turning left or right, and i think this DIY should fix the problem.
will I get those parts in autozone(i assume ordering OEM, shipping would cost more that the price of the parts)
Old Mar 25, 2014
  #125
Vexorg's Avatar
Vexorg is an unknown quantity at this point
Any chance someone has updated pictures?
Old May 20, 2019
  #126
Shane Welch's Avatar
Shane Welch is an unknown quantity at this point
Originally Posted by 2k2civic
Ok, that sounds great and all, but my 2002 LX coupe doesn't seem to want to slide up or down, it just has one hole where it is supposed to bolt on, not a sliding track like I have seen on older cars.
I have the Same issue in my 02 accord so I adjusted the rubber stops and instead of adjusting the latch mechanism i adjusted the strike that the latch closes to and i have to close it pretty hard (not quite slam) to get it to latch but it stopped a LOT of rattle. Now it's just behind the H above the license plate. Im gonna try stuffing some memory foam in it and see what it helps
hyper_silver
Jan 26, 2009 11:16 PM
LiceLocket
Oct 25, 2003 08:10 PM
ROBREALZCIVIC
Feb 25, 2002 04:08 PM
mavx5
15
Jan 23, 2002 05:07 PM
2k2civic
Dec 10, 2001 09:22 PM
