DIY Weapon-R Secret Fixing loose temp sensor...
Old Jan 24, 2009
  #61
Re: DIY Weapon-R Secret Fixing loose temp sensor...
yeah you can just install it like that already assembled. one trick i learned is you should get some sandpaper and sand off the outside of the filter inlet that goes in the rubber coupler. otherwise the filter has a tendency to fall out while driving. its too slippery i guess. also after you sand the filter, wipe it off with alcohol and also wipe inside the rubber connector.
Old Jan 24, 2009
  #62
Gumdrop's Avatar
Gumdrop is an unknown quantity at this point
okay ill do that, what grit sandpaper did u use?
your talking about this part of the filter correct?
Old Jan 24, 2009
  #63
like 80 grit? just to rough it up. yeah the very bottom you have in red. not the trim around the actual filter mesh
Old Jan 24, 2009
  #64
Gumdrop's Avatar
okay
yeah i figured that, couldnt find a good pic lol but thanks for the help
Old Jan 30, 2009
  #65
Gumdrop's Avatar
sry for double post
so i did this DIY, and it worked great, thankss!!!
theres the intake! (cell phone pic)
Old Jan 31, 2009
  #66
looks nice do you like the sound
Old Jan 31, 2009
  #67
Gumdrop's Avatar
yes yes very muchh =) i feel a tiny bit of power increase, but it could be my imagination =)
although when i drive i have a squeaking noise at about 1600 rpms (annoying as hell) and idk wut it is, it came when i had stock air system and now i have secret wr and its still there so its not my intake =// mechanic time next weekend
Old Jan 31, 2009
  #68
check for that stupid black ac hose hitting the neuspeed bar if you have one, or the metal ac lines hitting the car body. it might actually just be a loose belt tho?
Old Jan 31, 2009
  #69
Gumdrop's Avatar
okay ill check tomorrow when i can, but the odd thing...my car has to be in drive...in neutral or park it doesnt make the sound, so idk
Old Feb 1, 2009
  #70
yeah the motor shakes alot in drive. you may want to open the hood and see when someone else sits in the car with the car in drive and foot on brake.
Old Feb 1, 2009
  #71
Gumdrop's Avatar
alright ill do that, thanks, if i see anything...mechanic here i come =/ unless i can fix it
GolNat
Suspension DIY
May 12, 2022 06:49 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
Sarahwv2910
22
Jun 17, 2015 12:35 PM
Vaguexo
Jun 13, 2015 04:13 AM
cooldan1
Apr 23, 2015 10:49 AM
