DYI: Installing Walbro 255
Old Mar 29, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Installing Walbro 255 Fuel Pump!
Tools needed:
Phillips head screwdriver
Hamer
Flat head screwdriver
Saw or Dremmal tool
1) remove back seat to expose fuel pump assembly
2) Remove top plate:
3) using hammer and flat tip screw driver loosen the ring on the fuel pump:
4) Remove Fuel Pump:
5) Disassymble fuel pump assymbly and remove old fuel pump
*difference in fuel pumps Walbro silver Stock gold*
6)Cut a small nouch out of the rear of the fuel pan for a few hoese:
7) Cut top off old fuel pump assymbly and insert fuel pump:
8)Assemble Fuel pump assembly:
NOTE WRAP THE NEW HOUSE ON OUTSIDE OF THE ASSEMBLY! Makes it easier to get back in the tank.
Old Mar 29, 2006
dj02's Avatar
added
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
